Fuel pressure 1984 1.8 turbo
 Well I just pulled off the distributor cap and nothing. The damn timing belt must have broke.... I had spark a couple days ago so it must have happened since then. Guess its time to get dirty, any advice?
Rotor not turning?
84s do not have a timing belt
Sure it is 84?
I`ve seen the drive gear on the crankshaft strip,
Edited by naru
 It is wedged.. Now I cant even turn it. What am I going to damage if I pop the reluctor of the shaft and try moving it with vise grips? I can't find an exploded view of where the shaft lines up with the cam gear.
The drive gear is on the crankshaft,not the cam.
At this point,I would remove the crank seal to look at the drive gear and disty gear.
Sounds like you will need to do that anyway.
Be gentle on the crank gear.They are NLA new.
 Thanks, I am going to try the slide hammer trick real gently. I wasn't looking forward to dismantling every thing to get to the crank seal. This was just going to be a project and now it sounds like work... Lol
