97 legacy Posted March 5, 2018 Share Posted March 5, 2018 The fuel pump relay began a noticeable audible rapid clicking corresponding to the engine cutting out simultaneously, replaced the fuel pump relay,no change, jumped the relay n hot wired the pump still no change, it does somehow occasionally seem to click less after it warms up??? Help... anymore suggestions? Link to comment Share on other sites More sharing options...
idosubaru Posted March 6, 2018 Share Posted March 6, 2018 (edited) 1.verify for certain it’s the fuel pump relay? Maybe it’s not? 2. check engine light on? 3. Look at fsm schematic for fuel pump to see what is related. but someone will probably post. Edited March 6, 2018 by idosubaru 1 Link to comment Share on other sites More sharing options...
97 legacy Posted March 6, 2018 Author Share Posted March 6, 2018 It's definitely the fuel pump relay that is clicking, getting worse, acting like there is something shorting out the fuel system...... Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted March 6, 2018 Share Posted March 6, 2018 could this be a bad ECU ? or some pressure sensor in the fuel system? Link to comment Share on other sites More sharing options...
Gloyale Posted March 6, 2018 Share Posted March 6, 2018 Check the engine harness connectors, and the ground wire on the intake manifold. All ECU and IG and Fuel relays ground through that bolt to the intake. Link to comment Share on other sites More sharing options...
impostor Posted March 7, 2018 Share Posted March 7, 2018 ^^^ yup Link to comment Share on other sites More sharing options...
impostor Posted March 7, 2018 Share Posted March 7, 2018 Along the same concept as what gloyale said, make sure your battery connections are clean and tight, and make sure the large ground wire at the starter is tight. Link to comment Share on other sites More sharing options...
fgf Posted March 7, 2018 Share Posted March 7, 2018 Check wires to relay coil. I had exact same symptoms about 10 days ago and they were caused by cracked wire leading to the connector. The copper strands can fatigue crack inside the wire insulation. Link to comment Share on other sites More sharing options...
97 legacy Posted March 10, 2018 Author Share Posted March 10, 2018 It ended up being a bad plug wire arcing out on the manifold..... replaced the coIL an plug wires..... must of shorting an whacking out the electrical fuel system.... thanks for everyone's input ! ! ! Link to comment Share on other sites More sharing options...
heartless Posted March 10, 2018 Share Posted March 10, 2018 On 3/10/2018 at 6:21 AM, 97 legacy said: It ended up being a bad plug wire arcing out on the manifold..... replaced the coIL an plug wires..... must of shorting an whacking out the electrical fuel system.... thanks for everyone's input ! ! ! And this is why we recommend either OEM or NGK plug wires only. Store brand wires are crap. Link to comment Share on other sites More sharing options...
