I swapped my transmission but it is not lining up with the mounts....
Recently I installed a new transmission, but one side is not resting on the mount. There is about an inch of space straight up. It’s a gl-10 with an ej22 that has fresh mounts and a 93 pushbutton trans that also has fresh mounts. And the trans is fully bolted onto the engine. I can’t figure out why it’s just not falling into place.
Picture or explain better?
Support the engine and transmission weight so you can then twist it around and line up the engine mount holes in the crossmember.
Try unbolting the rear trans mounts from the back of the underbody to give more wiggle room.
