bratman18 Posted March 28, 2018 Share Posted March 28, 2018 On 3/28/2018 at 6:52 PM, comatosellama said: And this just leaves me wondering, is ADF selling snake oil with the adjustable links? Definitely not. Sometimes when lifting, the stock plastic endlinks don't hold up to the extra stress. Along with the fact they are at a harder angle do to their length. The adjustable ones just allow you to retain endlinks, and not have to worry about them breaking. 2 Link to comment Share on other sites More sharing options...
comatosellama Posted March 29, 2018 Author Share Posted March 29, 2018 On 3/28/2018 at 6:57 PM, Gloyale said: You're rear swaybar may be limiting the downtravel (since rear is bolted to body, not subframe, so doesn't drop with the lift like front does) Like I said, if you want to keep the rear sway, get the dropped brackets from an Outback or Forester And then learn how to drive a bit different. Brake before corner, nuetral throttle on entry, punch the gas out.....this will help keep the weight shifted to the back through the corner, instead of lurching forward and lifting the back end so much. Watch these guys........now THAT's body roll. ---www.youtube.com/watch?v=GYRQzarBOzo--- Might have to copy and paste without the dashes. Can't get the forum to accept this as a link??? Seems like I just need a lil more confidence. Started increasing steering output even when the car leans, and as long as I keep the balance kosher it sticks to the road. We’Lo see what drop brackets and sway bar add. IIRC it made a big difference on my 96 on outback struts Link to comment Share on other sites More sharing options...
comatosellama Posted March 31, 2018 Author Share Posted March 31, 2018 Installed the outback bar tonight, got the exact result I was looking for. Car is way tighter around corners and feels way better on the highway. Will do mounts soon Link to comment Share on other sites More sharing options...
Gloyale Posted April 19, 2018 Share Posted April 19, 2018 On 3/28/2018 at 6:52 PM, comatosellama said: And this just leaves me wondering, is ADF selling snake oil with the adjustable links? So, I've been thinking this over. And I was under a 06 forester the other day and it dawned on me......Oh yeah......the newer rigs with the subframe bracing !!! IMG_2938 by Dans Subaru, on Flickr IMG_2934 by Dans Subaru, on Flickr IMG_2933 by Dans Subaru, on Flickr ADF makes good stuff, and they aren't making products with no purpose. Wanted to put some context to this thread and why they may offer longer links. WRXs, and Forresters starting around 05???IIRC, use an additional brace that goes under the swaybar.....so on those models, a lift could cause the swaybar to hit the brace and limit downtravel. Longer links would be beneficial int his case. But to the OP of this thread, his 90's Impreza won't have that brace so the stock bar and links will still work fine. Link to comment Share on other sites More sharing options...
