93 ej22 motor with 02 Impreza transmission
Subaru = Lego.
Pick one ;)
We have a gen3 liberty (legacy) that's running a gen2 solid flywheel with the gen3 clutch pressure plate no worries. This was done to remove the squeaky dual mass flywheel.
Cheers
Bennie
Hang on, so is it a WRX gearbox or the NA Impreza box?
In my L series I'm running the phase two box (8 bolt) with the factory L series pull clutch setup mated to an EJ22E. I'm pretty sure I'm using a Gen1/2 clutch fork.
Find out exactly what the gearbox is for the most accurate help you can possibly get from other forum members. If you don't know what a term means, please ask!
There's a HUGE difference between the push and pull clutch setups!
Cheers
Bennie
