moosens Posted April 1, 2018 Share Posted April 1, 2018 Thanks for experienced input. Yes , I sure do normally get dealer parts. Up to this point I’ve had luck with well kept used of these pulleys , but it’s 2018 and time has drained local supplies. 2 Link to comment Share on other sites More sharing options...
moosens Posted April 1, 2018 Author Share Posted April 1, 2018 Yeah I did a search , just not coming up with what I recall being posted. Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 1, 2018 Share Posted April 1, 2018 6204 RSJ 6204 Rubber Sealed Journal Go to Napa and ask for that is SKF or something NOT made in China. Usually around $15-25 now for a decent quality bearing. The old bearing can be knocked out with a socket and hammer. New bearing knocked in with a socket that fits against the outer race of the bearing. 2 Link to comment Share on other sites More sharing options...
moosens Posted April 2, 2018 Author Share Posted April 2, 2018 Excellent ! Thanks !! Link to comment Share on other sites More sharing options...
Subaru Scott Posted April 2, 2018 Share Posted April 2, 2018 If you don't need it immediately, you can find great Japanese bearings online for 10 bucks or so. 1 Link to comment Share on other sites More sharing options...
moosens Posted April 2, 2018 Author Share Posted April 2, 2018 Yeah , not in a real rush. Thanks Scott , I’ll give it a look. Link to comment Share on other sites More sharing options...
idosubaru Posted April 2, 2018 Share Posted April 2, 2018 I order Japanese bearings on amazon for $10 each usually like Scott said. 1 Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 2, 2018 Share Posted April 2, 2018 (edited) yeah, look for Nachi bearings on Amazon. decent prices look on the present bearing closely to double check the number. the only bearing I know about is for the H6's serpentine system and it's 6203 like this; https://www.amazon.com/6203-2NSE-Bearing-17x40x12-Sealed-Bearings/dp/B0045E0E8U/ref=sr_1_2?ie=UTF8&qid=1522674228&sr=8-2&keywords=6203+nachi but they have several sizes Edited April 2, 2018 by 1 Lucky Texan 1 Link to comment Share on other sites More sharing options...
impostor Posted April 4, 2018 Share Posted April 4, 2018 +1 on the Nachi bearings yeah, look for Nachi bearings on Amazon. decent priceslook on the present bearing closely to double check the number. the only bearing I know about is for the H6's serpentine system and it's 6203like this; https://www.amazon.com/6203-2NSE-Bearing-17x40x12-Sealed-Bearings/dp/B0045E0E8U/ref=sr_1_2?ie=UTF8&qid=1522674228&sr=8-2&keywords=6203+nachibut they have several sizes Link to comment Share on other sites More sharing options...
moosens Posted April 25, 2018 Author Share Posted April 25, 2018 6203 or 6204 ? The one I removed had metal not rubber lube retainers. I’m ok with rubber if you guys have used them with great results. Thanks ! Link to comment Share on other sites More sharing options...
Subaru Scott Posted April 25, 2018 Share Posted April 25, 2018 The four numbers are the bearing size. Replace with like numbers. There will be a letter suffix which will designate seal type and other qualities of the bearing. Rubber is fine, probably seals better anyway. Metal is used where there is a chance for exposure to particles which would damage rubber. I think it's pretty well protected from anything like that. Unless you typically blast down gravel roads... tailgating trucks. Link to comment Share on other sites More sharing options...
moosens Posted April 25, 2018 Author Share Posted April 25, 2018 Scott , I can’t see the numbers on the old bearing. That’s why I’m asking since two different numbers were presented here in this thread. Link to comment Share on other sites More sharing options...
Subaru Scott Posted April 25, 2018 Share Posted April 25, 2018 Yeah, anymore for stuff like that I have to double up the reading glasses and/or break out the magnifying glass. Get it in the right light and hold your mouth just right. Otherwise, try to find your calipers. I have 3 cheap plastic ones, a digital, and a pen that is also a tiny caliper, and still can’t find one sometimes! Link to comment Share on other sites More sharing options...
moosens Posted April 26, 2018 Author Share Posted April 26, 2018 (edited) Lol , going to bring it into work and have an inspector look it over just for kicks. I’m going by our man Fairtax4me. Will order one later or tomorrow. Rubber , metal , whatever as long as it’s a name I know. Edited April 26, 2018 by moosens Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 30, 2018 Share Posted April 30, 2018 I think somewhere around 2000 they changed it. I grabbed a spare I had on a shelf and it had a 6203 bearing in it, but the one I put in my 96 a few years ago was deffinitely a 6204. Mame sure you get one with rubber seals to keep dirt/dust/water out. These bearings should not have metal seals for this application. Link to comment Share on other sites More sharing options...
moosens Posted April 30, 2018 Author Share Posted April 30, 2018 The one that came out was metal and as best as I can tell original. I went with an NTN. Was a sucker for the “German made”. Should be here next day or so. Thanks Link to comment Share on other sites More sharing options...
DaveT Posted May 1, 2018 Share Posted May 1, 2018 There are 3 kinds of seals: The metal shields, which are not really seals. Rubber seals, typically black. Contact rubber seals, typically reddish orange. The last are the best at keeping crud and moisture out and grease in. Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 1, 2018 Share Posted May 1, 2018 So the red and black rubber are actually different seal configurations, and not just different material? I did not know that. 1 Link to comment Share on other sites More sharing options...
moosens Posted May 1, 2018 Author Share Posted May 1, 2018 Ya know , you’d think I’d have looked at my other two first gen Legacys and see what they have. Lol Package got to me Monday. I’ll get it going sometime this week. Thanks for the info. Link to comment Share on other sites More sharing options...
moosens Posted May 1, 2018 Author Share Posted May 1, 2018 (edited) Well that bearing is too large. Maybe it’s for 95-99 Legacy ? 2.5? From the chart I’m looking at I’m guessing I actually need a 6202. The bearing I removed measured at 1 3/8” OD Working without calipers or micrometer at the moment. http://www.microbluebearings.com/bearing-size-charts/ Edited May 1, 2018 by moosens Link to comment Share on other sites More sharing options...
DaveT Posted May 2, 2018 Share Posted May 2, 2018 The color difference may not always translate across all manufacturers, but the contact seals I've bought all have the red color. The NTN, NSK, and Nachi bearings I have are all red. Also, if you look really close where the seal meets the inner race, depending on the brand, you can see a lip, or the gap is very close to non existent. Link to comment Share on other sites More sharing options...
moosens Posted May 2, 2018 Author Share Posted May 2, 2018 Ok thanks. The current issue is the size. The 6204 was too large. I’ve ordered a 6202 based on OD size. Link to comment Share on other sites More sharing options...
moosens Posted May 8, 2018 Author Share Posted May 8, 2018 (edited) 6202 was the correct size. And for those that read this far , keep in mind my Legacy is a 1992. The tensioner assy which has the three bolts in a triangular position for the 90-94 2.2 that’s the one explained here. I know you guys meant well , stuff happens. We do have a 97 Outback hoping to get on the road soon. I’ll save the 6204 for that car. Cheers Edited May 8, 2018 by moosens 1 Link to comment Share on other sites More sharing options...
