xdeadeye1 Posted April 2, 2018 Share Posted April 2, 2018 asking regarding 2000 Outback with 2.5 SOHC, Head Reinstall. IS THIS CORRECT? F A C D B E All Bolts 22 FP All Bolts 51 FP Back off all bolts 180 Back off all bolts 180 Again. All bolts to 31 FP All bolts turn 90 Degrees All bolts turn 45 Degrees Last Two center bolts (a, turn 45 degrees more. Link to comment Share on other sites More sharing options...
forester2002s Posted April 2, 2018 Share Posted April 2, 2018 See attached page ME60 from the 2002 Factory Service Manual. I'm not sure if the 2002 and 2000 2.5 SOHC are the same, but the torque details differ in a few places 2002 Subaru 2.5 SOHC FSM ME60 Cylinder Head Assembly.pdfFetching info... Link to comment Share on other sites More sharing options...
xdeadeye1 Posted April 2, 2018 Author Share Posted April 2, 2018 Thank you sir or maam. One last thing,, same car, 118 k miles. I'm ready to put this thing together but I don't have the oil pump o ring . Not to be confused with crank seal. Any way.. local Subaru says 3 days out. Anyone know a big box store alternate? I cant seem to find it. I thought I had it at napa Altrom brand PB3002 but its just a simple o ring. The one I believe is correct is not just a simple o ring. OR Do I just screw it,, and leave the old one in there.? Link to comment Share on other sites More sharing options...
xdeadeye1 Posted April 3, 2018 Author Share Posted April 3, 2018 Need some help here. I followed the torque sequence and got down to where I do the corner bolts at 11 FPs well,, that's about the lowest setting on this torque wrench. I started turning them and couldn't feel the torque wrench "CLICK" so I kept going and realized this isn't right. I thought I kept missing it,, so I kept doing the corner bolts in order. All with the same damn result. I have an inch lb wrench I should have switched to.. but I didn't. So what should I do next..? Back off all the bolts ALL OF THEM and start over? Back off the corner bolts a few turns and then turn them to 11 FPS with the inch lb torque wrench? (yes I can do the conversion to FPS) If I do this, is my head gasket ruined ? The center 2 bolts were done fine. no issues.. But I'm afraid my corner bolts are all over torque. Recommendations? Link to comment Share on other sites More sharing options...
xdeadeye1 Posted April 4, 2018 Author Share Posted April 4, 2018 2) Tighten cylinder head bolts.(1) Apply a coat of engine oil to washers andbolt threads.(2) Tighten all bolts to 29 N·m (3.0 kgf-m, 22ft-lb) in alphabetical sequence.Then tighten all bolts to 69 N·m (7.0 kgf-m, 51ft-lb) in alphabetical sequence.(3) Back off all bolts by 180° first; back them offby 180° again.(4) Tighten bolts (a) and ( to 34 N·m (3.5kgf-m, 25 ft-lb).(5) Tighten bolts ©, (d), (e) and (f) to 15 N·m(1.5 kgf-m, 11 ft-lb).(6) Tighten all bolts by 80 to 90° in alphabeticalsequence Link to comment Share on other sites More sharing options...
Mike104 Posted April 4, 2018 Share Posted April 4, 2018 The Oil Pump O-ring is not just an O-ring it was replaced with a specific seal. Personally I would wait for the part. Link to comment Share on other sites More sharing options...
