steve56 Posted April 3, 2018 Share Posted April 3, 2018 Have 07 Impreza. with jdm block.and usdm intake manifold.The jdm block has a tube in top of block where the usdm manifolds pcv would normally screw in.. How do I connect the pcv with this setup? Link to comment Share on other sites More sharing options...
Mike104 Posted April 3, 2018 Share Posted April 3, 2018 (edited) I used a piece of 3/4" rubber hose and put in a brass threaded bushing that would accept the PCV valve. Put a hose clamp on either end (on on the tube and one on the bushing end). The other end of the hose went to the tube on the JDM block. Edited April 3, 2018 by Mike104 Link to comment Share on other sites More sharing options...
steve56 Posted April 3, 2018 Author Share Posted April 3, 2018 Where do you connect the vacuum hose that goes to the front of air box. There is no connection in top of jdm block? Link to comment Share on other sites More sharing options...
Mike104 Posted April 3, 2018 Share Posted April 3, 2018 screw the PCV valve into that bushing and then connect the hose to the Intake Manifold. Mine didn't have a connection to the airbox. You could get a Y fitting at a parts store to connect it if needed Link to comment Share on other sites More sharing options...
