Feels like its running on 2 cylinders, 02 outback
Parked it a year ago after limping home at 30 to 40 MPH. Now daughter has decided she wants a car at college. Feeling like it lost a couple cylinders, installed a new coil tonight and the same thing. which way do i go?
Any codes ?  Pull the spark plugs yet ?  Might need to do a compression test on it. The fact that it still starts and runs leads me to think the timing belt isn't broken.  Edit) I should mention pulling the plugs is not quite as easy as it sounds.  Drivers side remove the windshield washer tank , pass side remove part of air intake system.
Edited by montana tom
1 year prior to parking, the heads were done, all new belt, tensioners, w pump, plugs, injectors, exhaust, brakes, steering. prepping for daughter but she decided that she did not need a car then.
sits here idling no miss, throttle up with no load, no problem.
+1 to getting the codes.  I have an 02 and the last time that I had a problem with it, I could hardly "limp" home just like the OP.  The code called for the knock sensor.  I replaced same and the car ran fine.
Just as a reminder to posters before they comment, the 02 subarus do NOT have a MAF.
