mkoch Posted April 5, 2018 Share Posted April 5, 2018 The videos.... 22 and 24 seconds I am trying to fix an oil leak at the rear min seal, but it looks like the larger ring isn't the thing that is leaking. It looks like an inner, orange ring is leaking, and that is not a part of the clutch replacement kit What is the name of the orange rubbery part? I think I need to replace it, because it looks like that's the only place the oil could've come from. Suggestions? Link to comment Share on other sites More sharing options...
Gloyale Posted April 5, 2018 Share Posted April 5, 2018 don't know what it's called, but yes it can leak. It's to keep the oil that runs in the center of the crank from coming out the end and getting through the bolt holes. I have had luck washing the old ring with warm water and dawn dish soap. DO NOT Use brake cleaner, it will swell the ring and make it unuseable. So wash it good to get all oil off, then use a smear of "the RIght Stuff" rtv on it before reinstall. Link to comment Share on other sites More sharing options...
jono Posted April 5, 2018 Share Posted April 5, 2018 Curious little blighter they are. My oldest 3/84 sedans EA81 does not even have one to leak ! No room on end of crank. EA82 deleted them. Subaru will still stock for sure. I even got a black one in a rebuild kit, but turfed it in preference for the used orange one. I used to always gunk them up with oil friendly sealants as a precaution.. How was the crank case pressure inside , not excessive blow by helping push the oil out ? Link to comment Share on other sites More sharing options...
mkoch Posted April 5, 2018 Author Share Posted April 5, 2018 Thank you, Gloyale! jono, how can I measure the crank case pressure? Link to comment Share on other sites More sharing options...
naru Posted April 6, 2018 Share Posted April 6, 2018 On 4/5/2018 at 9:24 PM, mkoch said: The videos.... 22 and 24 seconds I am trying to fix an oil leak at the rear min seal, but it looks like the larger ring isn't the thing that is leaking. It looks like an inner, orange ring is leaking, and that is not a part of the clutch replacement kit What is the name of the orange rubbery part? I think I need to replace it, because it looks like that's the only place the oil could've come from. Suggestions? Crankshaft o ring-413967100 Looks like they are NLA I`d use a genaric subsitute. Link to comment Share on other sites More sharing options...
