Jabbott126 Posted April 6, 2018 Share Posted April 6, 2018 (edited) So I came up with this idea since I have tons of spare stuff laying around and I don't feel like spending a small fortune on a lift kit. I'm going to try stacking the top hats for the front struts (I'm still working to see if that same idea might work for the rear) ill Remove the studs and use some grade 8 bolts That pull the top hats together. Also planning to double up the trailing arm spacers from my parts car for a slight body lift.Comments? Opinions? Suggestions? Edited April 6, 2018 by Jabbott126 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 6, 2018 Share Posted April 6, 2018 Too thin. Bad idea. Get real lift blocks. GD 1 Link to comment Share on other sites More sharing options...
idosubaru Posted April 6, 2018 Share Posted April 6, 2018 camber will be off. A lift block is offset to compensate. Link to comment Share on other sites More sharing options...
Gloyale Posted April 7, 2018 Share Posted April 7, 2018 Not safe. Do not attempt Link to comment Share on other sites More sharing options...
heartless Posted April 7, 2018 Share Posted April 7, 2018 would have to agree with all of the above... Not a good idea, not by any stretch of the imagination. If you want a lift, do it the right way - not hodge-podged together Link to comment Share on other sites More sharing options...
wtdash Posted April 9, 2018 Share Posted April 9, 2018 (edited) small fortune on a lift kit for <$50 you can get front and rear spacers. Paranoid fabrications is one option. Edited April 9, 2018 by wtdash Link to comment Share on other sites More sharing options...
ferp420 Posted April 9, 2018 Share Posted April 9, 2018 What ever happend to the napkin lift diagram that was a great resorce for a cheap 2" lift 1 Link to comment Share on other sites More sharing options...
Numbchux Posted April 9, 2018 Share Posted April 9, 2018 +1 for not strong enough and not corrected for camber. 1 Link to comment Share on other sites More sharing options...
comatosellama Posted April 16, 2018 Share Posted April 16, 2018 What ever happend to the napkin lift diagram that was a great resorce for a cheap 2" lift +1 Link to comment Share on other sites More sharing options...
