nkx Posted June 27, 2004 Share Posted June 27, 2004 a buddy and i were arguing the other day about what would be the best way to get lots of air to the air filter. i already have a big K&N cone in there. i suggested a custom passenger side (and possibly a similar drivers side) light that would use a smaller actual light, and the rest of the space would let air go directly to the filter, or possibly through prefilter first. this would be a compromise between completely taking out the passenger headlight, and being able to see at night. a hoodscoop right above the air filter would work too, but it involves less direct airflow. now my buddy says the filter shouldnt be exposed to a direct source (I.E. my first idea). he wants to use the factory ducting in the fender as the only source for fresh air, in a setup like skip's. this seems restrictive to me, especially when i plan on cranking up the boost. i want as much air into the engine bay as i can get, be it to cool the motor, or consumption by the engine. does anyone have any insight to this? which method do you think would be best? keep in mind that i am trying to "rally" this car... thanks Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 27, 2004 Share Posted June 27, 2004 I believe that SubaruTex did a nice intake setup on the RX. He got rid of the stock aribox completley, made an "box" by closing off the section where the airbox USED to be with a sheet of aluminum, cut a hole in the aluminum that the intake piping runs through and the MAF bolts onto, and then put a nice cone filter on it. It would help keep out the hotter air that is surrounding the engine while sucking in the cooler air that comes from outside the car. Here I found a pic of what I'm talking about to helpp you out!!!! http://www.subarutex.com/gallery/RX/Engine_Bay Quote Link to comment Share on other sites More sharing options...
suberdave Posted June 27, 2004 Share Posted June 27, 2004 here is a good pic of my car with some serious cold air induction -=Suberdave=- www.suberdave.com Quote Link to comment Share on other sites More sharing options...
theDirtyRue Posted June 27, 2004 Share Posted June 27, 2004 suberdave, Is that just pvc from a hardware store or sometyhing? Thanks, Quote Link to comment Share on other sites More sharing options...
suberdave Posted June 28, 2004 Share Posted June 28, 2004 suberdave, Is that just pvc from a hardware store or sometyhing? Thanks, you hit the nail on the head. works grate and only cost like $20 -=suberdave=- Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted June 28, 2004 Share Posted June 28, 2004 planning some deep water excursions i see Quote Link to comment Share on other sites More sharing options...
nkx Posted June 30, 2004 Author Share Posted June 30, 2004 i thought of shortening the tract in the fender, and have it open closer to the middle of the fender... but would that be worth the work seeing as i dont use the stock airbox anymore? air wouldnt really be sucked through it unless i made something to couple that with a surround for the filter... :-\ Quote Link to comment Share on other sites More sharing options...
suberdave Posted June 30, 2004 Share Posted June 30, 2004 im working on a intake that is going on my 93 loyale spfi. it will be done today, and i will have pics up tonight. sorry no PVC this time, this one is the real thing, 2.5 inch chrome pipe and a K&N filter -=Suberdave=- www.suberdave Quote Link to comment Share on other sites More sharing options...
rallyruss Posted June 30, 2004 Share Posted June 30, 2004 the intake piece inside the fender acts like a noise supressor. it can be removed to gain better air flow. this will not help you much unless you isolate you filter from the engine compartment hot air as previously sugested. you can make the opening to the inner fender bigger too. that seems to help. in all seriousness I would concentrate on installing an effective intercooler. Espically if you plan on raising boost levels. this will help your performance and relyability much more than a "street racer" intake will. Quote Link to comment Share on other sites More sharing options...
suberdave Posted July 1, 2004 Share Posted July 1, 2004 here are some pics of my 93 loyale, i know its spfi not turbo mpfi but it would work the same, just need some mod's. now i know its no PVC but i think it looks nice as you can see the Mass air flow senser is mounted right onto the sheet metal of the inner finder. here is how it mounts in the fender. should be a little colder out there and a bit more air can come through that K&N than the stock paper filter. and here is the whole thing. let me know what you think... -=suberdave=- www.suberdave.com Quote Link to comment Share on other sites More sharing options...
calebz Posted July 1, 2004 Share Posted July 1, 2004 Nice work man thats badass.. were you able to keep your windshield washer fluid resevior? Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted July 1, 2004 Share Posted July 1, 2004 Nice work man thats badass.. were you able to keep your windshield washer fluid resevior?that is awesome, but im afraid id suck up water.. Quote Link to comment Share on other sites More sharing options...
calebz Posted July 1, 2004 Share Posted July 1, 2004 that is awesome, but im afraid id suck up water.. I wouldn't be too afraid of it.. thats the area the factory airbox draws from anyway Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted July 1, 2004 Share Posted July 1, 2004 I wouldn't be too afraid of it.. thats the area the factory airbox draws from anywayyes, thats why mine breathes hot air from under the hood.. safety from hydrolock Quote Link to comment Share on other sites More sharing options...
rallyruss Posted July 1, 2004 Share Posted July 1, 2004 that sure does look a bit too close to the ground for much puddle spashing but there are a good deal of parts missing so it may be protected enough when all assembled. good cold air location. Quote Link to comment Share on other sites More sharing options...
calebz Posted July 1, 2004 Share Posted July 1, 2004 yes, thats why mine breathes hot air from under the hood.. safety from hydrolock Mine too.. but for a different reason.. I'm a cheapass and have made anything better yet Quote Link to comment Share on other sites More sharing options...
subaru_styles Posted July 1, 2004 Share Posted July 1, 2004 awesome job dave. thats a real cold air intake Quote Link to comment Share on other sites More sharing options...
nkx Posted July 1, 2004 Author Share Posted July 1, 2004 ah nice work there dave.... how big is that cone? the one i have now is 6". oh and russ, i have an intercooler from a chrysler conquest, but i have yet to install it. i need to get some mounting brackets of some sort made, and some piping. ive got an STi hoodscoop sitting around thats gonna provide fresh air for my IC. off topic: why isnt my sig showing anymore? Quote Link to comment Share on other sites More sharing options...
suberdave Posted July 1, 2004 Share Posted July 1, 2004 Nice work man thats badass.. were you able to keep your windshield washer fluid resevior? yep. it all fits nicely up behind the fender and washer taink.; not to worried about water that is what i have my other subaru for, see above pics, with PVC intake, if i hit water that high, i better start bulding a boat. and the cone is a 6 inch cone with a 3 inch outlet to the pipe. thanks for the comments -=Suberdave=- Quote Link to comment Share on other sites More sharing options...
calebz Posted July 1, 2004 Share Posted July 1, 2004 hmm.. tht looks like the same cone I am using.. maybe its time to look into doing something like that. where did you source the pipes from and how did you go about bending to fit? Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted July 1, 2004 Share Posted July 1, 2004 ah nice work there dave.... how big is that cone? the one i have now is 6".oh and russ, i have an intercooler from a chrysler conquest, but i have yet to install it. i need to get some mounting brackets of some sort made, and some piping. ive got an STi hoodscoop sitting around thats gonna provide fresh air for my IC. off topic: why isnt my sig showing anymore? it mounts to the factory spare tire holder easily Quote Link to comment Share on other sites More sharing options...
oobnuker Posted July 1, 2004 Share Posted July 1, 2004 here are some pics of my 93 loyale, i know its spfi not turbo mpfi but it would work the same, just need some mod's. now i know its no PVC but i think it looks nice as you can see the Mass air flow senser is mounted right onto the sheet metal of the inner finder. here is how it mounts in the fender. should be a little colder out there and a bit more air can come through that K&N than the stock paper filter. and here is the whole thing. let me know what you think... -=suberdave=- www.suberdave.com That's really cool - the only thing I would worry about is isolating the MAF from vibration. If you notice the stock airbox, it is isolated quite a bit by big rubber bushings. Other than that, it looks really nice and I imagine will give you some good results! Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted July 1, 2004 Share Posted July 1, 2004 That's really cool - the only thing I would worry about is isolating the MAF from vibration. If you notice the stock airbox, it is isolated quite a bit by big rubber bushings. Other than that, it looks really nice and I imagine will give you some good results!its isolated so it dosent resonate the intake buzzing into the passenger cabin.. Quote Link to comment Share on other sites More sharing options...
suberdave Posted July 2, 2004 Share Posted July 2, 2004 well i finaly got the whole intake done. took it for a spin around the block, deffently a whole lot better. better acc. sounds much deeper, and seems to have a better over all performance. although i have not had it on the freeway or anything, i guess i will find out tomorrow, on my way to work. o yeah someone asked where i got the tubeing i work as a tech for saturn, so what to use, http://www.spswebpage.com a saturn intake. just some cuts and now its not a saturn intake anymore, its a subaru intake. well im off to go driveing... -=Suberdave=- www.suberdave.com Quote Link to comment Share on other sites More sharing options...
88rxsedan Posted July 2, 2004 Share Posted July 2, 2004 im surprised its not plastc Quote Link to comment Share on other sites More sharing options...
