mkoch Posted April 13, 2018 Share Posted April 13, 2018 (edited) I am ready to put the engine in, but first I need to install the oil pump. "Keep Your Subaru Alive" says to not to use gasket sealant when installing the oil pump. The surface the pump will attach to is scratched, is "no gasket sealant" still the best course of action? Hopefully, picture below Edited April 13, 2018 by mkoch Link to comment Share on other sites More sharing options...
mkoch Posted April 13, 2018 Author Share Posted April 13, 2018 https://photos.app.goo.gl/fkH9M5mHvaNh6zRG2 Link to comment Share on other sites More sharing options...
lrgvanman Posted April 13, 2018 Share Posted April 13, 2018 The picture would not come up for me. I am guessing the required lack of sealant by use of the sheer paper gasket is likely because a lot of sealants squeeze into the pump and contaminate. Just a guess on my part. Good luck. If done correctly, you should obviously have no leaks but depending on just how deep those scratches are... Link to comment Share on other sites More sharing options...
Sapper 157 Posted April 13, 2018 Share Posted April 13, 2018 (edited) I am ready to put the engine in, but first I need to install the oil pump. "Keep Your Subaru Alive" says to not to use gasket sealant when installing the oil pump. The surface the pump will attach to is scratched, is "no gasket sealant" still the best course of action? Hopefully, picture below That paper gasket doesnt really do a lot of the sealing. most of it is done by the larger o-ring. How scratched are we talking? Like scotch brite scratches? or deep gouges? BTW thats a beautiful looking wagon! Edited April 13, 2018 by Sapper 157 1 Link to comment Share on other sites More sharing options...
Gloyale Posted April 13, 2018 Share Posted April 13, 2018 If you are really worried, smear a super thin little bit of sealant directly into the scratch, and then wipe off all excess. Then install like normal with paper gasket. 2 Link to comment Share on other sites More sharing options...
lrgvanman Posted April 13, 2018 Share Posted April 13, 2018 Sapper 157 is very right about the large O-ring's duty. Sorry, I did mine in my ea81 and wondered the same about sealing but it came out fine. Don't use shellac or the next removal will likely end up with destroying the pump housing. Link to comment Share on other sites More sharing options...
mkoch Posted April 13, 2018 Author Share Posted April 13, 2018 (edited) I bought the rebuilt kit for the oil pump. It has four o rings. I was unable to remove the two phillips head screws on the pump. Am I correct in saying I will be able to use only two of the o rings? Also, I am guessing that the thicker small o ring goes in the hole pictured. http://img.photobucket.com/albums/v493/weimadog/EA81_oil_pump_o_rings_zpsn2hxgi2h.jpg http://img.photobucket.com/albums/v493/weimadog/EA81_oil_pump_only_rings_zpsbsgz9jnj.jpg https://photos.app.goo.gl/fkH9M5mHvaNh6zRG2 Edited April 13, 2018 by mkoch Link to comment Share on other sites More sharing options...
jono Posted April 13, 2018 Share Posted April 13, 2018 grease is the safest sealant to use here or maybe a second gasket Link to comment Share on other sites More sharing options...
Sapper 157 Posted April 13, 2018 Share Posted April 13, 2018 yeah that tiny bit of scoring on the pump flange shouldnt be a problem. As far as the O-rings you are correct in both statements. Link to comment Share on other sites More sharing options...
Gloyale Posted April 14, 2018 Share Posted April 14, 2018 I was unable to remove the two phillips head screws on the pump. You need to. It will continue to leak if you don't. Mount it in a vice, and use an Impact driver if needed. But you are in for disappointment if you don't reseal that section.....that's were the action happens. Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 15, 2018 Share Posted April 15, 2018 The screws come out easily if you rap them with a punch before attempting removal. Also some valve lapping compound on your screwdriver helps. Paper gasket, no sealant. If you don't have the paper you could substitute a non hardening sealant such as Hylomar. VERY small amount. GD Link to comment Share on other sites More sharing options...
