submat Posted April 14, 2018 Share Posted April 14, 2018 Anyone with a suggestion on an after market radiator for a non-turbo 93 loyale? I put a hole in mine pulling my engine, ugh. Anyway, as I look at the pictures for radiators they say direct fit but the screw holes for ac fan and fan shroud don't look like they line up. Thanks for any help! Link to comment Share on other sites More sharing options...
idosubaru Posted April 14, 2018 Share Posted April 14, 2018 A radiator shop could maybe repair yours if it’s in ye metal portion of the radiator. But at this age they’re good to replace. You can’t seem to get what you want at stores? Did you look online eBay amazon - I usually check a couple and see what the difference might be. Maybe look up a 1988 loyal and it won’t get confused with legacy EJ stuff. Post a link and maybe folks can comment. Link to comment Share on other sites More sharing options...
submat Posted May 20, 2018 Author Share Posted May 20, 2018 time to vent... bought a apdi 8019305 radiator, suppose to be an exact fit. Went to install and couldn't get the top bolt holes to line up. Radiator sat about a 1/4 inch too high. Finally, after many hours was able to get it installed, then went to install the a/c fan and fan shroud and the damn threads don't match the original. What a pita! Link to comment Share on other sites More sharing options...
submat Posted May 21, 2018 Author Share Posted May 21, 2018 My bad, threads were fine. A trip to Napa and purchased a 6mm x 1.0 tap and chased the threads. That did the trick. Link to comment Share on other sites More sharing options...
carfreak85 Posted May 21, 2018 Share Posted May 21, 2018 You shouldn't have to chase threads on a brand new part though... Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 21, 2018 Share Posted May 21, 2018 On 5/21/2018 at 2:38 PM, carfreak85 said: You shouldn't have to chase threads on a brand new part though... Happens all the time - because Americans want cheap parts. Funny how we never have to do that on Japanese parts. Thing is - it was probably just paint in the holes. And if you can't handle chasing some threads you probably shouldn't be doing your own repairs. Still not a sign of quality though. I've gone almost exclusively to having the older brass/copper radiators repaired or re-cored. Heater cores too. If you have an original quality part like that it will pay in the long run to have it repaired. Also keeps your money local and pays a real craftsman for a valuable skill. GD 3 Link to comment Share on other sites More sharing options...
Subasaurus Posted May 21, 2018 Share Posted May 21, 2018 On 5/21/2018 at 3:41 PM, GeneralDisorder said: I've gone almost exclusively to having the older brass/copper radiators repaired or re-cored. Heater cores too. If you have an original quality part like that it will pay in the long run to have it repaired. Also keeps your money local and pays a real craftsman for a valuable skill. GD could not agree more, $10-$15 repair overhere from someone i know, i avoid the plastic/metal radiators at all costs, destined to fail. Link to comment Share on other sites More sharing options...
