steve56 Posted April 16, 2018 Share Posted April 16, 2018 (edited) Have 07 Impreza with two copper washers and a u shaped copper washer that hold the power steering pump hose on top of power steering pump with a bolt. Do the two washers go on the inside or the outside of the u shaped washer? Whatever I'm doing is incorrect because the power steering fluid is leaking from the connection between hose and pump. Edited April 16, 2018 by steve56 Link to comment Share on other sites More sharing options...
Fairtax4me Posted April 16, 2018 Share Posted April 16, 2018 It should only have the u-shaped washer. No other washers needed. 1 Link to comment Share on other sites More sharing options...
xdeadeye1 Posted April 16, 2018 Share Posted April 16, 2018 this is exactly where I had a problem, and wasn't sure if I put it back on correctly... Maybe just need to tighten the bolt more. What is the torque spec? Link to comment Share on other sites More sharing options...
