Tireman28 Posted April 17, 2018 Share Posted April 17, 2018 Will a Cobb access port work on this car. It’s a na ej25 sohc. And if so what one do I need to buy just as a tuner. Is there anymore options? 1 Link to comment Share on other sites More sharing options...
matt167 Posted April 17, 2018 Share Posted April 17, 2018 No Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted April 17, 2018 Share Posted April 17, 2018 Tireman, what's your goal with this car? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 17, 2018 Share Posted April 17, 2018 There are no tuner options for ANY of the Subaru non turbo vehicles except the BRZ. The other exception would be using an Enduring Solutions board on a 20G computer in a 90-94 Legacy. Not a tuner exactly but it would work with some small modifications due to the pinout being essentially the same. GD Link to comment Share on other sites More sharing options...
Tireman28 Posted April 17, 2018 Author Share Posted April 17, 2018 (edited) it is a round track asphalt race car. I'm having a 3000 race grind from delta cams, one over sti valves, and porting pretty heavy. just not sure if i will need a tune or not. i just don't want it to go to lean and bust something. and i also have the year wrong, its an 2003 Edited April 17, 2018 by Tireman28 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 17, 2018 Share Posted April 17, 2018 There is no way to tune the 2003. Which means its entirely possible (likely I would say) that it will be much too lean at WOT. Too much air, and not enough fuel because the stock mapping (which ignores the O2 feedback at WOT) will not have enough fuel or the correct timing for those modifications. GD Link to comment Share on other sites More sharing options...
L5wolvesf Posted April 17, 2018 Share Posted April 17, 2018 There is no way to tune the 2003. Which means its entirely possible (likely I would say) that it will be much too lean at WOT. Too much air, and not enough fuel because the stock mapping (which ignores the O2 feedback at WOT) will not have enough fuel or the correct timing for those modifications. GD I'm, obviously, no Subaru computer expert but I noticed you mentioned the BRZ above. So my thought here is - could he swap in a BRZ ECU onto his car and tune from there? Link to comment Share on other sites More sharing options...
Tireman28 Posted April 18, 2018 Author Share Posted April 18, 2018 Good question about the Brz computer. I wonder what year? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 18, 2018 Share Posted April 18, 2018 (edited) No. The BRZ is a direct injection engine with coil-on-plug ignition, 8 injectors, dual variable valve timing, etc. The crank sensor triggers are different and it has 4 cam sensors, not 1. Also the tuning for them is primarily based around adding forced induction, not tuning NA. GD Edited April 18, 2018 by GeneralDisorder Link to comment Share on other sites More sharing options...
matt167 Posted April 18, 2018 Share Posted April 18, 2018 The WRX ECU has been spliced into that generation Impreza. It's not exactly right and you need to swap drivers cam sprocket and crank sprocket from a later model that is not VVT. It has been done and then it could be tuned Link to comment Share on other sites More sharing options...
Tireman28 Posted April 18, 2018 Author Share Posted April 18, 2018 I’m listening Matt. Any advice on where to start? Link to comment Share on other sites More sharing options...
Subaru Scott Posted April 18, 2018 Share Posted April 18, 2018 Go look at Speeduino. DIY, open-source, standalone developed by Aussies. You can get into a basic setup for a couple hundred bucks. It is tunable and can be configured to function with sensors and injectors of your choosing. The future is now! 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 19, 2018 Share Posted April 19, 2018 I’m listening Matt. Any advice on where to start? How good are you with schematics and wiring? That's a very big job. GD Link to comment Share on other sites More sharing options...
Tireman28 Posted April 23, 2018 Author Share Posted April 23, 2018 How do I delete the rev limiter? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 23, 2018 Share Posted April 23, 2018 How do I delete the rev limiter? You have to swap not only the ECU, but all it's wiring plugs - mapping each wire from the old harness to the new harness. Then you need to either buy an Access Port ($600) and pay for the Cobb training/license for their tuning software ($150) or buy a Tactrix cable and flash adapter ($200) then learn to tune it with open source software such as ECUScan, or Rom Raider. Or you can do the ESL swap for $750 shipped from the UK plus a computer (93 to 96 WRX) and not have to do any real wiring. Just move a single ground wire. GD 1 Link to comment Share on other sites More sharing options...
Tireman28 Posted April 24, 2018 Author Share Posted April 24, 2018 How do I do the esl swap? Where do I start to buy the process? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 24, 2018 Share Posted April 24, 2018 http://www.enduringsolutions.com Link to comment Share on other sites More sharing options...
Tireman28 Posted April 27, 2018 Author Share Posted April 27, 2018 Car runs great has a spoob ton of power. Def needs to be tuned though. Not getting anywhere w the enduring solutions. I’ve emailed and there website is hard to navigate. I have no idea what I need to tune it. Link to comment Share on other sites More sharing options...
