whippet Posted April 17, 2018 Share Posted April 17, 2018 what years of rear axles will fit an 84 brat? Quote Link to comment Share on other sites More sharing options...
carfreak85 Posted April 18, 2018 Share Posted April 18, 2018 Any 4WD rear axle from an EA81 chassis built from 1980 through 1989, but ONLY from an EA81. The joints are interchangeable, AFAIK, but the axle shaft lengths may be different on the EA71/EA82 chassis. Quote Link to comment Share on other sites More sharing options...
whippet Posted April 18, 2018 Author Share Posted April 18, 2018 (edited) Thanks. That is what I thought but the EA81's are harder to find. Find new ones for EA82 but haven't seen any for EA81. Edited April 18, 2018 by whippet 1 Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 18, 2018 Share Posted April 18, 2018 Thanks. That is what I thought but the EA81's are harder to find. Find new ones for EA82 but haven't seen any for EA81. EA82 rear axle CV cups and joints can be fitted to EA81 shafts. that's how I rehab my EA81 axles. 90-94 Legacy rear axle inner cups will work as well. Quote Link to comment Share on other sites More sharing options...
subyrally Posted April 19, 2018 Share Posted April 19, 2018 this is good to know, I need to replace the inner cups that came off of my rx when I stripped it out. it appears that they sat in water when in storage and got pretty nasty looking. and of course, it was the only part I was trying to reuse from that axle. I am going with wrx suspension and hubs on my brat, with the drive line from the rx, so I was looking at playing mix and match with the axles to get everything to work together. thought I might be in trouble since I couldn't find rear axles for sale anywhere... Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 19, 2018 Share Posted April 19, 2018 this is good to know, I need to replace the inner cups that came off of my rx when I stripped it out. it appears that they sat in water when in storage and got pretty nasty looking. and of course, it was the only part I was trying to reuse from that axle. I am going with wrx suspension and hubs on my brat, with the drive line from the rx, so I was looking at playing mix and match with the axles to get everything to work together. thought I might be in trouble since I couldn't find rear axles for sale anywhere... EA82 axles will not mate up to WRX rear hubs. Wrong width. Wrong outer end hook up. Quote Link to comment Share on other sites More sharing options...
subyrally Posted April 19, 2018 Share Posted April 19, 2018 EA82 axles will not mate up to WRX rear hubs. Wrong width. Wrong outer end hook up. Thats why i said that the only part i was trying to reuse was the inner cups. i already have the rest of what i need for the conversion, but the inner cups i have from my rx are rusted. i can probably get by with them until i can find another set, but i dont want to have them on there any longer than i have to. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted April 19, 2018 Share Posted April 19, 2018 Thats why i said that the only part i was trying to reuse was the inner cups. i already have the rest of what i need for the conversion, but the inner cups i have from my rx are rusted. i can probably get by with them until i can find another set, but i dont want to have them on there any longer than i have to. They won't fit ont eh WRX axles. The splines on the 95+ stuff is different. Just use a WRX rear diff (or any 95+ r160) and the entire WRX axles if that is what you are planning. No need to use RX cups 1 Quote Link to comment Share on other sites More sharing options...
subyrally Posted April 19, 2018 Share Posted April 19, 2018 im using the rx rear diff and drivetrain. i kinda need to stick with cups that will fit on the rear diff. Quote Link to comment Share on other sites More sharing options...
bratman2 Posted April 22, 2018 Share Posted April 22, 2018 Are the axles bad or just the boots? A dozen or so years ago i pulled mine because the boots looked like they were about dry rotted. Cleaned them, greased them, rebooted them and swapped them from left to right. Almost a quarter of a million miles and they are still good. Quote Link to comment Share on other sites More sharing options...
