jeryst Posted May 4, 2018 Author Share Posted May 4, 2018 I'm still confused about the oil pan issue. My new PCV just arrived, so I will be installing it to see if it makes a difference. I'm pretty confident that oil consumption jumped after the new pan was installed. I believe it was made by Spectre, or something like that. Does anyone have pictures that show the difference between a stock Subaru pan and an aftermarket in the area that might cause the problem? Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 4, 2018 Share Posted May 4, 2018 (edited) We build turbo engines all the time with the Killer-B motorsports pan and it does not seal in that location: http://www.killerbmotorsport.net/oiling-products/oil-pans/high-performance-oil-pan-ej-series.html Moroso builds their pan the same way: https://www.rallysportdirect.com/part/oil-pans/mor-20966-moroso-steel-oil-pan We don't experience any oil consumption due to the lack of a seal for the oil return port. The aftermarket stock style pan (likely made by Dorman) does have the seal just like the factory pan. GD Edited May 4, 2018 by GeneralDisorder Quote Link to comment Share on other sites More sharing options...
Gloyale Posted May 4, 2018 Share Posted May 4, 2018 While not having a seal, both of those pans have a box section that comes up flush with the pan flange. Might not be a perfect seal, but not the open gap that happens when one reseals a stock pan and neglects to install the O-ring. Quote Link to comment Share on other sites More sharing options...
jeryst Posted June 4, 2018 Author Share Posted June 4, 2018 Update: Replaced the PCV and it didn't make any difference. Quote Link to comment Share on other sites More sharing options...
vtwinjunkie Posted June 14, 2018 Share Posted June 14, 2018 On 4/28/2018 at 8:48 AM, idosubaru said: wow, if it wasn't you i wouldn't believe that at first glance! this joker fixed it before he missed one morning oil top off before work...his odds weren't in his favor. makes me want to stuff a PCV hose shut and see what happens for a 100 miles just to see it myself. i've got a running and driving 03 going to the scrap yard, it's tempting. wait why is it going to the scrapyard if it runs and drives?! Quote Link to comment Share on other sites More sharing options...
montana tom Posted June 14, 2018 Share Posted June 14, 2018 Must be rust out. 1 Quote Link to comment Share on other sites More sharing options...
el_freddo Posted June 15, 2018 Share Posted June 15, 2018 I've read that full synthetic oil will burn without creating a smoke cloud out the back of the vehicle. Mum's '03 Corolla would use 1L of oil for every 4-500km of driving! Not anything to see out the back to suggest it was burning oil. We believe the cylinders in this engine were badly glazed. It was replaced with another known good engine. You could be running an oil that's too thin for the wear in your engine too. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 15, 2018 Share Posted June 15, 2018 1 hour ago, el_freddo said: I've read that full synthetic oil will burn without creating a smoke cloud out the back of the vehicle. Mum's '03 Corolla would use 1L of oil for every 4-500km of driving! Not anything to see out the back to suggest it was burning oil. We believe the cylinders in this engine were badly glazed. It was replaced with another known good engine. You could be running an oil that's too thin for the wear in your engine too. Cheers Bennie Cylinder "glaze" is a fantasy. The rings were shot and plugged up with failed oil. GD Quote Link to comment Share on other sites More sharing options...
