Ea81 Radiator....stuff Help!
I have an 85 Brat that's a 3AT that I've almost finished putting back together after head gasket replacement. I got a new radiator off of Rock Auto. My question is is there a difference between the radiator in Auto and manual or are they the same. It looks like my OEM one except the radiator cap hole is bigger and the inside of the reservoir looks different. I'm making sure it still works as the auto trans cooler. I have pics if needed.
Link to radiator:
https://www.rockauto.com/en/catalog/subaru,1985,brat,1.8l+h4,1267747,cooling+system,radiator,2172
Hi there,   i have an 86 GL wagon with the 3AT and my radiator has an internal transmission cooler built in.  you should make sure to get the radiator that has the tranny cooler.  The connections are on the  driver's side of the radiator.  there is a brass screw in fitting that has a factor bend to help the hoses that come off the tranny to connect in a good direction.  if u have your old radiaror still u can take that one off.  That's what i did.   best of luck
