Knucklehead Saloon Posted May 3, 2018 Share Posted May 3, 2018 (edited) Hey Gang ! Today I replaced my worn old rubber bushes with Nolathane ones on my front swaybar. The job was a cinch, took 35 mins all up and was doable without jacking the car up. I ordered the parts from ebay and have included pix for anyone else looking to do the same. The Nolathane kits were great as they came with bushing lube as well. Skoob handles the corners a whole bunch better now and sits better at highway speeds as well. Edited May 4, 2018 by Knucklehead Saloon 1 Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 3, 2018 Author Share Posted May 3, 2018 Ok does anyone know how to make the links show up as photos pls ? Link to comment Share on other sites More sharing options...
el_freddo Posted May 3, 2018 Share Posted May 3, 2018 ^ remove the * from the last coding bracket. The trick is working out how to share the photo on a forum - you'll need to find the specific code on your photo account to share it as using that link address doesn't work, nor does the one once the image is displayed in your account on my screen. So it's something you'll have to find within your photo account to see it on the forum I hope that's clearer than mud! Cheers Bennie Link to comment Share on other sites More sharing options...
jono Posted May 3, 2018 Share Posted May 3, 2018 Cost total in oz dollars? Link to comment Share on other sites More sharing options...
carfreak85 Posted May 3, 2018 Share Posted May 3, 2018 Make sure you continue to lube those puppies. Urethane really doesn't like to be installed in twisting applications (such as sway bar mounting bushings). They prefer compression forces and will eventually start to squeak and wear our in a rotational application, unless lubed frequently. Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 4, 2018 Author Share Posted May 4, 2018 Jono: mate I bought em a while back from ebay, from memory they were 70 bucksish delivered. Carfreak 85: thanks for the tip mate ! 1 Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 4, 2018 Author Share Posted May 4, 2018 Jono: one kit was 22mm and the orher 17mm ID Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 4, 2018 Author Share Posted May 4, 2018 Right !! Got the pics working (thanks el_fredo). Turns out google photos was the culprit. Went with tinypic hosting instead and works like a dream. Link to comment Share on other sites More sharing options...
jono Posted May 4, 2018 Share Posted May 4, 2018 (edited) Right !! Got the pics working (thanks el_fredo). Turns out google photos was the culprit. Went with tinypic hosting instead and works like a dream. Sure does, they aint such tiny pics either. I can only get thumbnails up. May need to investigate tiny pics one day That bush be hard enough to drill a lube hole into, screw in a grease nipple on the back side and easy to keep the maintenance up to it Think one pic turned the lens around on you Edited May 4, 2018 by jono Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 4, 2018 Author Share Posted May 4, 2018 Yeah that's my ugly mug under the car right there haha. Link to comment Share on other sites More sharing options...
el_freddo Posted May 4, 2018 Share Posted May 4, 2018 I've not had an issue with the Nolathane bushes on my rear swing arms of my L series. They lasted about 200k km with quite a bit of offroading in there too. I think this event ultimately began their demise: Mind you, with that said, the above event happened in 2010 and the bushes were swapped out in 2016 and they were obviously well worn by that point. New units are in there now doing what they do best Cheers Bennie 1 Link to comment Share on other sites More sharing options...
carfreak85 Posted May 4, 2018 Share Posted May 4, 2018 YMMV, but urethane needs more frequent maintenance than rubber bushings. Another trick it to wrap the anti-roll bar in Teflon tape before you install the bushings. This should outlast any grease, but will still need to be replaced every so often. Link to comment Share on other sites More sharing options...
DaveT Posted May 4, 2018 Share Posted May 4, 2018 This is all interesting to read. I've been thinking about replacing the 30yr old rubber in my suspension systems... but I don't want to add maintenance items. Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 5, 2018 Author Share Posted May 5, 2018 I had urathane rubbers in a little packet in my pocket once... no wait... wrong rubbers haha ! But seriously, over the years I've put them in a ton if cars, swaybars, radius rods, shock absorbers etc. I used to use antisieze as lube and it lasted very well. Also used waterproof grease on occasion but didn't last as many yrs as the antisieze. The kits I used on Skoob came with their own lube. Pretty sure its a black molybedenum grease. Dry swaybar bushes are far and away the major cause of squeaky front ends. Cheers. Link to comment Share on other sites More sharing options...
carfreak85 Posted May 22, 2018 Share Posted May 22, 2018 Well gang, looks like I'm jumping on this bandwagon. Nolathane upper anti-roll bar endlink bushings, Superpro lower anti-roll bar and leading rod bushings for the EA82. I'll report back once installed with some miles on them. 1 Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 23, 2018 Author Share Posted May 23, 2018 Keen to hear your report mate ! Link to comment Share on other sites More sharing options...
bzzltyr Posted May 27, 2018 Share Posted May 27, 2018 Great info, Making me want go look at the bushs on my 86 BRAT. Already dark here in Colorado, USA. Won't stop me, got a flashlight in my pocket all the time. Link to comment Share on other sites More sharing options...
bzzltyr Posted May 27, 2018 Share Posted May 27, 2018 Amazing! Something I don't need to fix! At 250K miles, the left front sway bar bushing is the only one showing any wear, and only slight. Groovy Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 27, 2018 Author Share Posted May 27, 2018 Mine were knackered at 140k miles Link to comment Share on other sites More sharing options...
