6 speed transmission in 2003 Impreza rs.
The question is why. If you only run 3rd and 4th. The 6spd is a waste. Gear ratio's are very close for 4th- 5th in a 6spd to 3rd -4th in a 5spd
This is for the WRX 5spd. Your 4.11 RS/ Forester transmission has a bit different gear ratio but you could save a TON by just going with a WRX 5spd
2002-2007. Clutch systems changed in 2006 wrx back to a push style cluch which is what the RS trans is, but with a different slave cylinder for a 2002-2005 WRX, you can use either transmission
The front diff is 3.90 ratio, and with the 1.1:1 center diff, the rear diff is 3.54
6 speed swaps are getting fairly cheap. You can use a 04/05 transmission with an R160 3.90 diff and the front driveshaft from an automatic model Impreza. You will need 05+ WRX front axles, automatic driveshaft, clutch, flywheel, and slave cylinder. Also the DCCD Pro controller if you want to adjust the front/rear differential bias.
We do this swap all the time to the WRX's. It's not really any different on a non-turbo.
He is limited to 2wd ( frt or rear ), and shifts between 2 gears. A 6spd is a waste of money in this case
I have to run 2wd. And prefer front because of the handling is way better and I can set my stagger up better that way. I was lookin at the 3.90 gear and using a msd dis 2 to increase my limiter to 7300
