4wd93loyale Posted May 8, 2018 Author Share Posted May 8, 2018 And rear defrost was 1.250 v both sides Link to comment Share on other sites More sharing options...
DaveT Posted May 8, 2018 Share Posted May 8, 2018 Ok need my manuals, they are at home. Another thing check one of those good ones, but with the key in run position. If it stays good, that indicates that you don't have a flakey connection in that first level of circuitry. If the power goes away, you back track toward the battery. Link to comment Share on other sites More sharing options...
DaveT Posted May 9, 2018 Share Posted May 9, 2018 Power goes to the ignition switch on a fat white wire. Power to the engine & ECU etc. is a Black wire. Should only be 12V when ignition is in run and start positions. It goes to the 3 fuses for: Meter Engine IG-COIL FUEL ECC Back Turn 4WD AT Those should all have 12V with the key in run & start positions. Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 12, 2018 Author Share Posted May 12, 2018 Haven’t had a chance to look at her more, will be working on her all Tuesday hopefully I get a running Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 13, 2018 Author Share Posted May 13, 2018 No power to those 3 fuses with key on Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 13, 2018 Author Share Posted May 13, 2018 I had power to the fuse box a few days ago now I don’t have any Link to comment Share on other sites More sharing options...
DaveT Posted May 14, 2018 Share Posted May 14, 2018 So the power at the fuses listed in post #25 is gone, as well as nothing in post #28?Have to start testing back toward the battery. Starting to sound like a corroded or broken connection. Link to comment Share on other sites More sharing options...
el_freddo Posted May 14, 2018 Share Posted May 14, 2018 Battery any good? I had a flat battery recently in one of our cars and it did some seriously weird stuff. The battery being flat was a result of a dead alternator... Cheers Bennie Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 19, 2018 Author Share Posted May 19, 2018 This car is going to be the dearth of me. Now I have no power at the links but I got power at the wires going into the links from the bottom, still no power at any fuses ......anyone please HELPPPPP Link to comment Share on other sites More sharing options...
DaveT Posted May 19, 2018 Share Posted May 19, 2018 That points to something at the fusible link box. Power has to go through the links to get to the fuse box. Careful inspection. All the connections need to be clean metal, no corrosion. The metal tabs can be removed. You want to check that the crimps are good also. I made a tool for removing the contacts from fuse blocks connectors, etc. From one of the stainless steel strips on the side of some windshield wiper blades. Depending on the particular connector, grind some width or thickness down so it fits - there is a plastic catch on the housing or a metal tab on the contact. Use the stainless steel strip to get into there and to release it. Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 20, 2018 Author Share Posted May 20, 2018 I’m about to ready to junk this thing I hate electrical issues, thank for all your advice Link to comment Share on other sites More sharing options...
DaveT Posted May 20, 2018 Share Posted May 20, 2018 Trying to run one of these old cars, you have to know or learn how to fix everything or have a load of cash to pay one of the rare places that will work on them. I'm guessing you are nowhere near Connecticut Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 20, 2018 Author Share Posted May 20, 2018 I’m close to CT depends on what part lol Link to comment Share on other sites More sharing options...
DaveT Posted May 20, 2018 Share Posted May 20, 2018 I'm in colchester, pretty much the center of the state Link to comment Share on other sites More sharing options...
el_freddo Posted May 20, 2018 Share Posted May 20, 2018 Seems like you've got a place to start... And that's at least something. I'm hoping you checked those fusible links properly - they may be solid/not broken but they can still be dead. All the best with it. Don't give up! Cheers Bennie Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 21, 2018 Author Share Posted May 21, 2018 I'm in colchester, pretty much the center of the state Yeah that’s about 1hr40mins from me. You work on these vintage gems? What’s your rate Link to comment Share on other sites More sharing options...
DaveT Posted May 21, 2018 Share Posted May 21, 2018 I'm not a pro mechanic. But I have been maintaining and repairing my EA82s since 1988. Electronics engineer. I was designing and building electric and electronics since before high school. Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 21, 2018 Author Share Posted May 21, 2018 I actually was testing the links wrong, I was tired retested them and they are all showing 12.5. Just nothing to the fuses key in or off Link to comment Share on other sites More sharing options...
Dee2 Posted May 21, 2018 Share Posted May 21, 2018 If power is not going from fusible links to fuse box then you need to check the wires/connectors in between. Disconnect battery and do a continuity check on the wires. Link to comment Share on other sites More sharing options...
Gloyale Posted May 21, 2018 Share Posted May 21, 2018 I actually was testing the links wrong, I was tired retested them and they are all showing 12.5. Just nothing to the fuses key in or off nothing to any fuses? or nothing to the ones that should get "key on" voltage? If the latter, the problem is at the ignition switch. If the former, the main wire to teh cabin. Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 21, 2018 Author Share Posted May 21, 2018 No power to any fuses key in or out. I just changed the ignition relay thinking that was the problem but nothing, or at least that’s what I think I changed lol, it was brown and above the computer and still nothing Link to comment Share on other sites More sharing options...
DaveT Posted May 21, 2018 Share Posted May 21, 2018 It's not a relay problem. Some of the fuses have power all the time. Some only when key is on run position. There is a relay for some other circuits also, but it doesn't matter if you don't have the always on and the switched power from the ignition switch. Anyone have scans of the schematic online? Link to comment Share on other sites More sharing options...
4wd93loyale Posted May 23, 2018 Author Share Posted May 23, 2018 Can the ignition switch cause no power in the fuses? I’m so lost when it comes to electrical it’s sad. Mechanical is my strong side Link to comment Share on other sites More sharing options...
DaveT Posted May 23, 2018 Share Posted May 23, 2018 Some of the fuses are switched by the ignition switch. So, yes, if there were an open circuit between the always on feed to or from the ignition, switch, it could cause the switched fuses to never get power. The always powered ones are not effected by the ignition switch, the are fed directly from the fusible links. A wire could be broken inside, or a connection or crimp could be loose and corroded, causing the intermittent troubles. 1 Link to comment Share on other sites More sharing options...
djellum Posted May 24, 2018 Share Posted May 24, 2018 id replace your fuseables just in case. i have had issues with other vehicles from faulty but not fully broken fuseables causing the cpu to fail safe and not power up. still had juice but it was intermittent weirdness and no start or even crank over. I doubt it will solve your problem but worth the $6 to me. keep the ones you pull in a baggy for emergency use. I'm certainly not the electrical person here, but have you unplugged the AC unit and bypassed the belt that drives it? if its fully locked up or otherwise faulty who knows what it is contributing to. Link to comment Share on other sites More sharing options...
