submat Posted May 8, 2018 Share Posted May 8, 2018 So spec says .002 tolerance for head surface. Anyone try head gasket repair with larger tolerance or is that a must to follow? Well the heads seem to be ok it is actual block surface that seems to be out on the .002 tolerance. So hard to get anything in there to get it flat with the alignment pins. 1 Link to comment Share on other sites More sharing options...
DaveT Posted May 8, 2018 Share Posted May 8, 2018 I have just used the post apocalyptic head resurfacing method described in an old thread on thus forum. Once you grind the marks from the fire ring off, they are flat. Link to comment Share on other sites More sharing options...
submat Posted May 8, 2018 Author Share Posted May 8, 2018 Oh cool, I was hoping to hear that! Link to comment Share on other sites More sharing options...
DaveT Posted May 8, 2018 Share Posted May 8, 2018 Also you should be able to tell with that method - the sand marks should be even across the entire face, and the head should not rock. Link to comment Share on other sites More sharing options...
submat Posted May 8, 2018 Author Share Posted May 8, 2018 That is great info! Thanks so much! Link to comment Share on other sites More sharing options...
ferp420 Posted May 9, 2018 Share Posted May 9, 2018 You can pull the alignment pins out with vice grips and level the block out a bit also Link to comment Share on other sites More sharing options...
