ajslacker Posted May 16, 2018 Share Posted May 16, 2018 I have a bent valve in an 85 Brat A/T. I want to replace it but I can't find any place that specifically has the Large valve. Rock Auto says it has it but i looked and the 82 Brat in their catalog uses the same valve part number. And correct me if I'm wrong but pre 84 had smaller valves... I just don't want to buy it pull the head and find out its the wrong one. Link to comment Share on other sites More sharing options...
el_freddo Posted May 17, 2018 Share Posted May 17, 2018 If you haven't pulled the head how do you know it's a bent valve? Have you tried adjusting the rocker arm clearances? If you're worried about getting the wrong valve, ask the shop you buy from about their return policy, and if they allow you to return an unused item I'd be ordering both valve sizes. I reckon the issue is either a bit of get on stuck on the valve seat or the rocker arm clearances. Best of luck with it. Cheers Bennie 1 Link to comment Share on other sites More sharing options...
GeneralDisorder Posted May 17, 2018 Share Posted May 17, 2018 They are no longer available. You will have to find used or contact a place like Manley and custom valves made. 2 Link to comment Share on other sites More sharing options...
ajslacker Posted May 18, 2018 Author Share Posted May 18, 2018 @el_freddo Sorry I forgot to follow the topic. Honestly Bent valve is just a guess I have not pulled the head yet but I plan to this weekend. I did adjust the valve clearance and I'm 99% sure I did it correctly but it still taps. I did run it for about a minute and a half with tapping valve so I'm assuming I bent it. I thought the tapping was a tool rattling around. I'm dumb. ???? @GD Lovely. Any chance the ea82 valves are the same size?? I assume they're not but it's worth a try. If not I'll just try something custom Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 18, 2018 Share Posted May 18, 2018 I'm sure you didn't bend a valve, so don't pull that head just yet. Go through your valve adjustment again and be sure you have it right. If it runs bad afterwards, do a compression test before going any further. Link to comment Share on other sites More sharing options...
ajslacker Posted May 18, 2018 Author Share Posted May 18, 2018 Alright will do. Link to comment Share on other sites More sharing options...
el_freddo Posted May 18, 2018 Share Posted May 18, 2018 Yeah no bent valve there for sure! If you're going by a tapping sound it seems to me as Subaru Scott said - valve adjustment. Tapping can be due to the section of the arm that comes in contact with the valve wearing oddly (I can't remember what it's called), this wear doesn't allow you to ever get the valve clearances just right to get rid of the tapping sound. I've got one arm like this on my ea81. You can remove the rocker arms (Which requires two head bolts to be removed) and have the surface refaced to remove this adjustment issue. Or just live with a bit of the tappety-tap. It's an ea81 after all - and nothing like the "tick of death" of the ea82 Cheers Bennie Link to comment Share on other sites More sharing options...
ajslacker Posted May 18, 2018 Author Share Posted May 18, 2018 Awesome that's great! When I do the valve clearance for the hydraulic valves, after I get to the zero point how much farther do I turn the adjustment bolt? I've seen everything from one and a half to 1/8 of a turn Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 18, 2018 Share Posted May 18, 2018 Do the procedure exactly as mkoch outlined in his post. 1 1/2 turns. But you must be sure you are on the compression stroke at top dead center. This is something you should probably have the designated valve adjustment tool with the thumbscrew knob in order to feel your zero point accurately. Fumbling around with pliers or a crescent wrench leaves too much time for the lifter to take up the slack before you can get another bite. Link to comment Share on other sites More sharing options...
ajslacker Posted May 18, 2018 Author Share Posted May 18, 2018 Ok. Ya I used a random on 6mm crescent wrench I found. I work at a Subaru dealership so I should be able to find a valve adjustment tool. Thanks for the help y'all. Link to comment Share on other sites More sharing options...
