brus brother Posted May 17, 2018 Share Posted May 17, 2018 2005 OB auto Noticed past few weeks, only in reverse. Seems to be coming from mid car and not wheels. Universal joint?Are they serviceable on this model/year? Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 18, 2018 Share Posted May 18, 2018 If it happens once per wheel rotation it's brakes or such. If it happens 4x per wheel rotation it's a u-joint. If it gets faster in rhythm much faster than you speed up, that is 4x wheel rotation, it's pretty noticeable. 1 Link to comment Share on other sites More sharing options...
brus brother Posted May 19, 2018 Author Share Posted May 19, 2018 only happens in reverse... if u-joint, are these serviceable? Link to comment Share on other sites More sharing options...
montana tom Posted May 19, 2018 Share Posted May 19, 2018 Not serviceable at home. Drive line replacement is common. Used or new . Link to comment Share on other sites More sharing options...
brus brother Posted May 19, 2018 Author Share Posted May 19, 2018 (edited) if it is that center bearing (not the standard u-joint), has anyone tried tapping in a grease fitting? Is there room within the bearing housing for such a move? Edited May 20, 2018 by brus brother Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 21, 2018 Share Posted May 21, 2018 If it is rythmic squeak like the video it's a U joint. Quite often they only make noise in reverse. Link to comment Share on other sites More sharing options...
brus brother Posted May 21, 2018 Author Share Posted May 21, 2018 (edited) If it is rythmic squeak like the video it's a U joint. Quite often they only make noise in reverse. what video? i see there is a swf file that neither my windows or linux computer wants to open... Edited May 21, 2018 by brus brother Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 22, 2018 Share Posted May 22, 2018 (edited) Huh, link and video is gone, trying again. well strange can't even link to a youtube video. On youtube search with quotes "silverado bad u-joints" Edited May 22, 2018 by CNY_Dave Link to comment Share on other sites More sharing options...
msmithmmx Posted May 22, 2018 Share Posted May 22, 2018 Any chance it sounds like this? Link to comment Share on other sites More sharing options...
CNY_Dave Posted May 23, 2018 Share Posted May 23, 2018 That sounds like the shaft scraping against something. Link to comment Share on other sites More sharing options...
brus brother Posted May 24, 2018 Author Share Posted May 24, 2018 yup cny that silverado ujoint sounds about right anyone every tap in a grease fitting for that center bearing i have been told by local shops that the drive shaft isn't serviceable... Link to comment Share on other sites More sharing options...
DaveT Posted May 24, 2018 Share Posted May 24, 2018 A good local shop can modify the "non serviceable" U joint mounts. At least the local one here did with my older Loyale "non serviceable" driveshaft. The U joints on my 09 Forester look pretty much the same as the ones on the Loyale shaft, although I have not measured them. Link to comment Share on other sites More sharing options...
msmithmmx Posted May 24, 2018 Share Posted May 24, 2018 It does appear you can replace the U joint. I only hear that sound in reverse as well Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 24, 2018 Share Posted May 24, 2018 Yeah, you have to dremel out the “staking” to get the old ones out. I haven’t done it yet but that’s what I understand others have done. I’m going to try to use a hole saw without a pilot but, if I can find one just the right size. Mine are stiff after 500k. Tried drilling to get some grease in there, but the metal is just too hard. Link to comment Share on other sites More sharing options...
DaveT Posted May 24, 2018 Share Posted May 24, 2018 The bearings are pretty destroyed by now, grease won't put the metal back. The needles get out of round, grooves get formed on the race surfaces. Link to comment Share on other sites More sharing options...
Subaru Scott Posted May 24, 2018 Share Posted May 24, 2018 Sure, there's that. But c'mon, I bet I could get another 15-20k out of it Link to comment Share on other sites More sharing options...
DaveT Posted May 24, 2018 Share Posted May 24, 2018 Yeah, you might. .. Link to comment Share on other sites More sharing options...
brus brother Posted May 25, 2018 Author Share Posted May 25, 2018 (edited) simple? Edited May 25, 2018 by brus brother Link to comment Share on other sites More sharing options...
