If it happens once per wheel rotation it's brakes or such.
If it happens 4x per wheel rotation it's a u-joint.
If it gets faster in rhythm much faster than you speed up, that is 4x wheel rotation, it's pretty noticeable.
  • Like 1
  On 5/21/2018 at 5:49 PM, CNY_Dave said:
If it is rythmic squeak like the video it's a U joint.
Quite often they only make noise in reverse.
what video?
i see there is a swf file that neither my windows or linux computer wants to open...
Edited by brus brother
Huh, link and video is gone, trying again.
well strange can't even link to a youtube video.
On youtube search with quotes "silverado bad u-joints"
Edited by CNY_Dave
A good local shop can modify the "non serviceable" U joint mounts.  At least the local one here did with my older Loyale "non serviceable" driveshaft.  The U joints on my 09 Forester look pretty much the same as the ones on the Loyale shaft, although I have not measured them.
Yeah, you have to dremel out the “staking” to get the old ones out. I haven’t done it yet but that’s what I understand others have done.
I’m going to try to use a hole saw without a pilot but, if I can find one just the right size.
Mine are stiff after 500k. Tried drilling to get some grease in there, but the metal is just too hard.
