86BRATMAN Posted May 26, 2018 Share Posted May 26, 2018 Any Subaru 5mt will fit in the ea81 auto tunnel with the mounts fabbed up. I have an ej awd 5mt in mine with no clearance problems at all. Link to comment Share on other sites More sharing options...
el_freddo Posted May 26, 2018 Share Posted May 26, 2018 Dual and single range are both the same dimensions, so no difference in fitment Cheers Bennie Link to comment Share on other sites More sharing options...
Gloyale Posted May 26, 2018 Share Posted May 26, 2018 On 5/25/2018 at 12:57 PM, Lofti7 said: I don't plan on bashing it our anything that could be considered hard core 4 wheeling it will get trips up to ski resorts and a weekend driver mostly. And one cross country trip. Are there problems with the single range transmissions or is the dual range just a better fit. dual range uses lever activation. Single uses vac solenoids. In this case, since you don't alradey have a lever, it would be one more thing to add. A single range 4wd from a loyale or DL might be just the ticket for ya. non-turbo so will be 23 spline and 3.9 final. Link to comment Share on other sites More sharing options...
Lofti7 Posted June 2, 2018 Author Share Posted June 2, 2018 Okay guys, I was able to find a single range trans from a 85 for a pretty good price they had a dual but what ever wreck it came from left scars all over it and a broken axle stub that scared me away. So I'll swap to the single range for now and go to dual later if I feel the need. I need shifter and linkage along with the center console, at this point color doesn't matter. also looking for a rear diff in a 3.9 23 spline if anyone has these our can point me in the right direction I would appreciate it. Link to comment Share on other sites More sharing options...
carfreak85 Posted June 4, 2018 Share Posted June 4, 2018 Do you want an open differential or an LSD? Link to comment Share on other sites More sharing options...
Lofti7 Posted June 5, 2018 Author Share Posted June 5, 2018 I found a 3.9 and a console with all linkage, thanks for all the PM's and help from everyone. My last hurdle will be getting the swap done. Link to comment Share on other sites More sharing options...
carfreak85 Posted June 5, 2018 Share Posted June 5, 2018 Also, I had to clearance my transmission to not tap on the tunnel. Sounds like people have had different experience though. Link to comment Share on other sites More sharing options...
Lofti7 Posted June 22, 2018 Author Share Posted June 22, 2018 I can't express the amount of gratitude I have to all of you for taking the time to help me get this done. First test drive was tonight, no issues noticed. Couldn't have done it without all of your help. Reverse and 4x4 light ate wired up and I'm just waiting on the console and a few small things to be finished. I had to customize the trans mounts for some reason but other than that it was a pretty smooth experience. BTW Where does the spring on the shift linkage go? 2 Link to comment Share on other sites More sharing options...
carfreak85 Posted June 26, 2018 Share Posted June 26, 2018 On 6/22/2018 at 1:36 AM, Lofti7 said: I can't express the amount of gratitude I have to all of you for taking the time to help me get this done. First test drive was tonight, no issues noticed. Couldn't have done it without all of your help. Reverse and 4x4 light ate wired up and I'm just waiting on the console and a few small things to be finished. I had to customize the trans mounts for some reason but other than that it was a pretty smooth experience. BTW Where does the spring on the shift linkage go? Expand Picture of the spring, to jog my memory? Link to comment Share on other sites More sharing options...
Lofti7 Posted June 26, 2018 Author Share Posted June 26, 2018 I figured it out, I was missing the bracket so I made one works great and shifter isn't so floppy. It's item 21 this isn't my exact shifter but I looked through a few of these and it seemed they are fairly common. Link to comment Share on other sites More sharing options...
carfreak85 Posted June 28, 2018 Share Posted June 28, 2018 Ahhhh, yeah, it's a washer/bracket combo part, probably still available from the dealer. EA shifters just suck, even with delrin bushings. Link to comment Share on other sites More sharing options...
