LeolaPA Posted May 19, 2018 Share Posted May 19, 2018 A couple years ago I replaced a front axle on one of my old Subarus, and I found that I could just pry the axle with the stubby shaft on the inboard side and get it out without having to mess with the roll pin while under the car. I changed the stub shaft to the new axle and popped it back in. HOWEVER....all the videos I see online, nobody does that. They all punch out the roll pin while under the car, and leave the stub axle in the transmission. Is there any harm to doing it by popping it out? Seems like there was a spring ring that held it in..... I'm doing another one this weekend, and I'm more cautious because it is my daughter's car.... Thanks for any comments. Link to comment Share on other sites More sharing options...
colemanapp Posted May 19, 2018 Share Posted May 19, 2018 I've only removed the roll pin. Sometimes the passenger side is easier to drive out from the top due to the exhaust being in the way from underneath. 1 Link to comment Share on other sites More sharing options...
Mike104 Posted May 19, 2018 Share Posted May 19, 2018 I think the only downside of taking out the stub shaft is the possibility of breaking the spring clip inside the transaxle. But I have done it both ways without much issue on my 99 1 Link to comment Share on other sites More sharing options...
LeolaPA Posted May 19, 2018 Author Share Posted May 19, 2018 I don't know if this will work, but here is a link to a video where they pulled the shaft out. If the link is no good, it is on Youtube, and it is Keith and Kevin's repair and restorations and the video is called How to replace a CV Joint in a 1996 Subaru Legacy AWD Auto Part 2 Stub Shaft / CV Joint Install Link to comment Share on other sites More sharing options...
idosubaru Posted May 19, 2018 Share Posted May 19, 2018 (edited) Yeah they pop out. You risk damaging the seal the stub shaft rises against or loosing the circlip, none of those happen much in practice but the roll pins are so easy Id rather leave the trans side alone. My guess is it would be many an axle change before you ever encountered an issue. So statistics are in your favor. But Gloyale or GD May know better if these have any substantial failure modes since they see this stuff weekly if not daily. Edited May 19, 2018 by idosubaru 2 Link to comment Share on other sites More sharing options...
nvu Posted May 19, 2018 Share Posted May 19, 2018 I use roll pin method on my impreza and can wedge out the axle without needing to take apart any suspension components. Pretty sure that wouldn't be possible with the stub method. Also you won't spill gear oil all over if you leave the stubs in. Pins are easy to get to on the impreza, not sure how much access there is under a legacy though. Link to comment Share on other sites More sharing options...
LeolaPA Posted May 20, 2018 Author Share Posted May 20, 2018 OK, well I removed the axle yesterday, and I just gave it a jerk, and it came right out. I didn't need to pry. Those roll pins are so hard to get to on the passenger's side, I just went ahead and this worked fine. I believe in later years the stub that goes into the transmission is actually part of the axle, so that's what you have to do on those models. No fluid leaked out with the axle out. 1 Link to comment Share on other sites More sharing options...
Mike104 Posted May 21, 2018 Share Posted May 21, 2018 OK, well I removed the axle yesterday, and I just gave it a jerk, and it came right out. I didn't need to pry. Those roll pins are so hard to get to on the passenger's side, I just went ahead and this worked fine. I believe in later years the stub that goes into the transmission is actually part of the axle, so that's what you have to do on those models. No fluid leaked out with the axle out. My 03 Forester has the stub shaft built as part of the axle so no worries. Getting that roll pin out on jack stands is a bear. Link to comment Share on other sites More sharing options...
