mkoch Posted May 20, 2018 Share Posted May 20, 2018 1984 4WD GL, I need to replace the axle shafts, front. 200,000 miles, seems like a good idea to replace the front wheel bearings and seals while I am at it. What else should I do on this job? Quote Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted May 20, 2018 Share Posted May 20, 2018 While the front end is totally pulled apart I'd suggest inspecting / replacing the following: - swaybar bushes (go with nolathane) - front struts (shock absorbers) - disc pads - disc rotors Quote Link to comment Share on other sites More sharing options...
colemanapp Posted May 20, 2018 Share Posted May 20, 2018 ball joints Quote Link to comment Share on other sites More sharing options...
el_freddo Posted May 21, 2018 Share Posted May 21, 2018 Tie rod ends and inspect/replace rack ends too. Then a wheel alignment. Or just do the shaft and ball joints, do an alignment and leave it be. I would replace bearings unless they looked like the grease was dry or they're making noises when driving. Cheers Bennie Quote Link to comment Share on other sites More sharing options...
Dee2 Posted May 21, 2018 Share Posted May 21, 2018 check transmission seals at axle connection for leaks. Quote Link to comment Share on other sites More sharing options...
