theDirtyRue Posted June 27, 2004 Share Posted June 27, 2004 Okay, When I'm driving down the road, sometimes it seems like I'm not getting all the power to the wheels. I can't really punch it anymore. The RPM's just go up and I slowly start moving. I have a bad CV in the passenger front. Could this be the culprit, or is it something bigger, worse... the Tranny? Anyone know what my problem is and how I can fix it? Thanks, Quote Link to comment Share on other sites More sharing options...
baccaruda Posted June 27, 2004 Share Posted June 27, 2004 might be time to change the clutch. it is a manual, right? you can loosen the clutch cable a little to try giving it a little more grab for a while. Quote Link to comment Share on other sites More sharing options...
theDirtyRue Posted June 28, 2004 Author Share Posted June 28, 2004 Yes, it is a manual. How would I loosen the cable? If I loosen it and it doesn't help, does that rule out the clutch? Thanks again, Quote Link to comment Share on other sites More sharing options...
Craven Posted June 28, 2004 Share Posted June 28, 2004 Yes, it is a manual. How would I loosen the cable? If I loosen it and it doesn't help, does that rule out the clutch? Thanks again, No, that more than likely means it's time for a new clutch. and while your at it, change the rear crankshaft seal. Quote Link to comment Share on other sites More sharing options...
Nug Posted June 28, 2004 Share Posted June 28, 2004 If you wanna milk it for a while, drive slower. Rapid acceleration will surely make it slip. Quote Link to comment Share on other sites More sharing options...
theDirtyRue Posted June 28, 2004 Author Share Posted June 28, 2004 How hard is a clutch swap? Is it something I can do by myself in an afternoon? How much should I expect to pay for it all? Thanks again, Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 28, 2004 Share Posted June 28, 2004 The clutch kit should be a little over $100 (it varies quite a bit depending on if you buy a rebuilt one or not, and where you get it), and you can do it, but it requires pulling the engine or the transmission. I personally like to pull the engine, but on an EA82 the trans might be simpler if you don't have a hoist. An engine hoist would make the job a lot easier. Someone who has done one before could do it in probably a couple hours. If you haven't, then set aside an entire day, or maybe a couple or them - like a weekend maybe. Once they start slipping like that - they tend to go VERY quickly, and when they do you will have no forward movement at all. In other words you would have to be towed home. If it were me I would stop driving it till you can get the clutch done. GD Quote Link to comment Share on other sites More sharing options...
theDirtyRue Posted June 29, 2004 Author Share Posted June 29, 2004 Alright, So you guys are all positive that it is the clutch? I don't mean to doubt or second guess you guys at all, but I just don't have the money to be spending it on the clutch and have that not be the problem. Is there any test or something that I can do? If it is the clutch, what's easier, pull the engine or drop the tranny? If i drop the tranny maybe i could swap it out for the D/R...? Thanks GD, I'll try and get my dad to let me drive the pick up for a bit. Thanks again, Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 29, 2004 Share Posted June 29, 2004 Test.... try going up a hill at about 25 MPH in 2nd gear, and then change to 5th gear. The engine should lug down when you release the clutch. If it doesn't, then your clutch is going. You can also just pull the engine and take a look at it. You will understand when you see it...... Pulling the engine is easier if you have a hoist. Pulling the tranny is less complicated, but it's heavy, and unless you have a couple friends - difficult to re-install. GD Quote Link to comment Share on other sites More sharing options...
theDirtyRue Posted June 29, 2004 Author Share Posted June 29, 2004 Alrighty, I'll try the hill thing tommorow. I don't have a hoist, but i might have axcess to one. This will most likely be a weekend project then, b/c none of my friends have done the clutch swap. O well, a learnig experience for all of us. Thanks again, Quote Link to comment Share on other sites More sharing options...
Turbone Posted June 29, 2004 Share Posted June 29, 2004 How did you line up the clutch/PP with the pilot bearing? Quote Link to comment Share on other sites More sharing options...
Turbone Posted June 29, 2004 Share Posted June 29, 2004 Thats what I assumed you used. Just was wondering if there was enough room. Good to know it can be done. Quote Link to comment Share on other sites More sharing options...
