Steering/Suspension Parts Unavailable. where can I find them?
Hello people,
I’m working on a 92 Subaru Loyale, and I need to replace my control arm, unfortunately the only place I could find the correct control arm was on eBay. And it’s used. Ok. That’ll be ok. My only issue now is, I’m trying to find the sway bar link kit/stabilizer link kit to connect my sway bar to the control arm. Absolutely nothing. Does anyone know where to get stabilizer links for older subies?
Used is your only option at this point, I don't think there were ever aftermarket control arms available.
The anti-roll bar end links are basically just crimped bar stock on the EA82s, you can fabricate your own without problems.
Yep, the link itself was just a pair of flat metal pieces (with some shape stamped in for strength) with 2 holes in them.
I assume the bushings are available. I bought a steel sleeve that goes on that bolt inside the bushing for my XT6 this winter...
I think they have the older catalogs on here: https://parts.subaru.com/
Edited by Numbchux
3 hours ago, 1 Lucky Texan said:
just a guess, maybe something could be fabricated from tubing with the ends smashed flat?
Possible. But much simpler to use flat stock. Go a little thicker than OE, and it should be fine. 3/16" would probably be perfect.
  • Like 1
