ClassySoob Posted June 21, 2018 Share Posted June 21, 2018 (edited) I'm in the middle of an EJ22 swap with my 85 GL. I managed to pick up an engine, but did not get the whole donor car. I would like to know what wiring harness is needed for the swapped engine to run. Just from the ECU to the necessary engine components? Any help would be great!!! Thanks. Edited June 21, 2018 by ClassySoob Link to comment Share on other sites More sharing options...
ClassySoob Posted June 21, 2018 Author Share Posted June 21, 2018 And also what type of fuel pump should I use? To run injection. Link to comment Share on other sites More sharing options...
alexbuoy Posted June 22, 2018 Share Posted June 22, 2018 You will need the whole bulkhead harness under the dash. People use the fuel pumps from the SPFI EA82s and they work fine. I think my brats running something from a ford crown vic Link to comment Share on other sites More sharing options...
el_freddo Posted June 22, 2018 Share Posted June 22, 2018 Fuel pump = efi high pressure pump, external variety is the one to get. As for wiring, it depends on which generation and series the engine came from - or get the wiring harness as previously mentioned, intake manifold and associated wiring/sensors etc AND the crank and LH cam gears (these will have matching timing marks for the ECU). Or find a donor vehicle of the same Gen your engine came from that has the same number of plugs for the engine to body harness - this is *usually* a way to match the intake harness to the main harness and have it all work as it should. Cheers Bennie Link to comment Share on other sites More sharing options...
ClassySoob Posted June 23, 2018 Author Share Posted June 23, 2018 (edited) Thank you. So will I need to swap out all the wiring with my 85? Would a harness form a 2.5 work? Edited June 23, 2018 by ClassySoob Link to comment Share on other sites More sharing options...
Subaru Scott Posted June 23, 2018 Share Posted June 23, 2018 No, just remove all the unnecessary wires from the engine donor harness and add it in the vehicle to run the engine systems. The rest of the wiring can remain unchanged. Just have to parallel connections at the ignition switch and instrumentation, and run wiring to the new fuel pump. Easy peasy. Link to comment Share on other sites More sharing options...
el_freddo Posted June 23, 2018 Share Posted June 23, 2018 Yeah what Scott said. If going an ej25 harness, why not run an ej25? Cheers Bennie Link to comment Share on other sites More sharing options...
ClassySoob Posted June 23, 2018 Author Share Posted June 23, 2018 9 hours ago, el_freddo said: Yeah what Scott said. If going an ej25 harness, why not run an ej25? Cheers Bennie I have the 2.2 engine and it's harness. But I need the rest of the wiring. Computer to engine. I found a 2.5 wiring. Will that work, or is it different? Link to comment Share on other sites More sharing options...
el_freddo Posted June 24, 2018 Share Posted June 24, 2018 Definitely different but in what ways I don't know. And by harness I/we mean the ECU and associated wiring to the engine. Cheers Bennie Link to comment Share on other sites More sharing options...
