whynot Posted June 27, 2018 Share Posted June 27, 2018 99 outback wagon, When I use the auto down feature the window goes down, then up and down about 1/8 inch until it stops, then it will not work at all for a few minutes. If I roll the window down by myself, it will also do this at the very bottom of the travel. Why is it doing this, and how do I fix it? is it the regulator or the switch in the door, or am I missing something else? Thanks Link to comment Share on other sites More sharing options...
gbhrps Posted June 27, 2018 Share Posted June 27, 2018 whynot, Many electrical systems can reset themselves if the battery is disconnected for 10 minutes or so. I would wonder if this strange goings on might also. No guaranty, but its an easy fix if it does. Link to comment Share on other sites More sharing options...
whynot Posted June 28, 2018 Author Share Posted June 28, 2018 Tried that today, it did not help. Link to comment Share on other sites More sharing options...
gbhrps Posted June 29, 2018 Share Posted June 29, 2018 whynot, Here's the factory service manual for 1999, and its a FREE download. Download it (10 minutes) and save it and do some research through the electrical section under windows as well as the diagnostics section and see if your answers are there. Over the years I've done this so many times that I just can't involve myself as much as I used to. Your answers may well be there somewhere, but You'll have to do the work. Good Luck! http://jdmfsm.info/Auto/Japan/Subaru/Legacy_Outback/1999/Service%20Manual/ Gene Link to comment Share on other sites More sharing options...
wtdash Posted June 30, 2018 Share Posted June 30, 2018 That. is. weird. Sounds like it's mis-aligned in there somewhere and it's 'bouncing off' the bottom 'stop' setting'. It then stops - maybe a self-reset or similar - to keep from burning out the motor. Pulling the inner door panel isn't too tough and you might be able to see what's going on. Link to comment Share on other sites More sharing options...
whynot Posted June 30, 2018 Author Share Posted June 30, 2018 I did not think about it being physical. I was sure it was electric. I will have to pull the door panel in a couple of weeks, and see if I can find something like that. Link to comment Share on other sites More sharing options...
CNY_Dave Posted July 2, 2018 Share Posted July 2, 2018 On some cars I think the 'stop' for auto-down is actually a current sensor, it senses the motor has stalled and it disconnects power, and unlatches the power. My '03 outback and '05 forester both had/have auto-down, with no sensors anywhere to detect window position. So auto-down weirdness in those cases could be abnormally high motor current. Link to comment Share on other sites More sharing options...
whynot Posted July 4, 2018 Author Share Posted July 4, 2018 Where is the sensor at? motor or switch or somewhere else? It goes down fine, all of the way. then it comes back up 1/4 inch and back down several times, then stops and will not work for about 1 minute. Link to comment Share on other sites More sharing options...
el_freddo Posted July 4, 2018 Share Posted July 4, 2018 You need to find the electric window auto control box. In older subi's (MY/L series) it's a rectangular black box mounted above the bonnet release handle. I'm not up with where it's located on newer models but that's what I'd be looking at first. Swap in a known good working unit and see if the same behaviour occurs. or you could have an issue with the motor itself, but this seems unlikely to me. Also ensure the switch is clean without any foreign material interfering with it's operation or electrical signals. Cheers Bennie Link to comment Share on other sites More sharing options...
uniberp1 Posted July 5, 2018 Share Posted July 5, 2018 Or it stops working completely because the motor is overheating. Overheating can also cause excesses current draw, hence the stop action. Clean up the motor, if possible. Link to comment Share on other sites More sharing options...
whynot Posted August 7, 2018 Author Share Posted August 7, 2018 I could not find anything obviously wrong with this. The window is in the track, and looks like it is moving fine, I also could not find a box above the fuse box or the hood release for the window control box. Found some relays there, but no control box. did not see a box in the wiring diagram but I am new to those for a subaru. Link to comment Share on other sites More sharing options...
