Lofti7 Posted July 1, 2018 Share Posted July 1, 2018 Not having much luck searching for one mine is leaking pretty severely. do any other years swap with a 83? Or is there a rebuild kit? Or should I delete it and put a manual rack in? Link to comment Share on other sites More sharing options...
silverhelme Posted July 1, 2018 Share Posted July 1, 2018 Look up on Rockauto for an '83 Brat turbo, they offer a rebuild service for $95. Link to comment Share on other sites More sharing options...
el_freddo Posted July 2, 2018 Share Posted July 2, 2018 I'm pretty sure the ea81 turbo shares the same power steering pump as the ea82... Some one will be able to clarify this Cheers Bennie Link to comment Share on other sites More sharing options...
czny Posted July 2, 2018 Share Posted July 2, 2018 Only difference is high pres fitting & resevoir between the years 83 & 87. Change fitting on later pump & you should be golden. Look at the pics on RockAuto for 83 & 87 gls for differences. I'd have to dig for it but I may have the late resevoir & a core pump. 1 Link to comment Share on other sites More sharing options...
carfreak85 Posted July 2, 2018 Share Posted July 2, 2018 I concur with czny. The reservoir is unique to the EA81T. Link to comment Share on other sites More sharing options...
Lofti7 Posted July 2, 2018 Author Share Posted July 2, 2018 I saw the rebuild service just didn't know if that was my only option. Thanks again guys. Link to comment Share on other sites More sharing options...
Crazyeights Posted July 3, 2018 Share Posted July 3, 2018 You might try an EA82 pump as I think it's possible that only the mounting bracket is different between the EA82 and EA81T pumps. It's worth a look anyway. I have both here so I'll compare them and get back to you if I can find them in storage. Link to comment Share on other sites More sharing options...
Lofti7 Posted July 3, 2018 Author Share Posted July 3, 2018 5 hours ago, Crazyeights said: You might try an EA82 pump as I think it's possible that only the mounting bracket is different between the EA82 and EA81T pumps. It's worth a look anyway. I have both here so I'll compare them and get back to you if I can find them in storage. Thanks, comparing pictures now I'll probably try the rock auto rebuild service but it's good to have options Link to comment Share on other sites More sharing options...
jono Posted July 4, 2018 Share Posted July 4, 2018 Subaru don't do a kit as such for the EA82 Series one, they did it piece by piece. I bet you can pull yours apart, get seals and bearings from even a bearing shop and be done. Did mine years ago. Circlip pliers were handy Link to comment Share on other sites More sharing options...
