bork Posted July 1, 2018 Share Posted July 1, 2018 I found a cheap 2003 Forester with messed up motor. I have a rusted out 99 Impreza L 4 door, with good engine. Does anyone know if this is an easy transplant? Also the Forester has approx 204K miles on it. Would this be kinda high mileage for the trouble of the swap? Link to comment Share on other sites More sharing options...
wtdash Posted July 2, 2018 Share Posted July 2, 2018 (edited) Hmmm. not sure why no one has responded...although this is covered elsewhere. The Phase2 2.2 in your '99 should work if you swap the intake manifold from the Foz and the exhaust manifold from the Imp. If the Foz is an Automatic use its flex-plate. I'd also do the HG while it's out as that Phase 2 will likely have issues like the 2.5's. Edited July 2, 2018 by wtdash Link to comment Share on other sites More sharing options...
bork Posted July 3, 2018 Author Share Posted July 3, 2018 Thank you! What is "oz"? and I understand about exhaust manifold, but why intake? Link to comment Share on other sites More sharing options...
wtdash Posted July 3, 2018 Share Posted July 3, 2018 Foz = Fozzie = Forester...google. Intake and it's wiring need to match the '03...so keep the '03. Link to comment Share on other sites More sharing options...
bork Posted July 3, 2018 Author Share Posted July 3, 2018 Thanks Link to comment Share on other sites More sharing options...
Mike104 Posted July 3, 2018 Share Posted July 3, 2018 You may also have to swap the Crankshaft gear and Drivers side Cam Gear from the Forester, if they have different timing triggers 2 Link to comment Share on other sites More sharing options...
el_freddo Posted July 3, 2018 Share Posted July 3, 2018 You might find the intake bolt pattern is different as they changed it somewhere around this time. if that's the case, swapping the heads from your ej20 onto the ej22 can be done. It may result I higher compression or no change at all - but the intake will bolt on. Cam wheel/gear swap will definitely be required. All the best. Cheers Bennie Link to comment Share on other sites More sharing options...
