Ej swap alternator
You'll need the wiring from the alternator to the main loom. Then splice this into the existing EA loom.
relatively simple to do. Just make sure you solder and insulate your joints really well ;)
Cheers
Bennie
Just for the information,  the risk in using the old existing wire is that it is not sized for the higher output of the modern alternator.  The stock fusible link should cover most failure modes ok, but not allow the full use of the higher output.
