el_freddo Posted July 14, 2018 Share Posted July 14, 2018 (edited) Ok so I've read many times recently on the forum to re-ring with a head gasket replacement. I've read the article provided by GD in another thread about why you don't home to "deglaze" a bore or to bed new rings in. What I'd like to know is the procedure of how to go about re-ringing the engine from the time the pistons are out. Basically in terms of: - What needs to be checked? - How is this checked? - Do you buy standard rings for the given engine and call it a day or is it more technical than this (eg, measuring bore to piston clearances with a wire gauge then work out required ring size from this?) I ask these as I'm about to do this to an engine to get one of my project cars going and want to be clear about how to do this properly. I know @GeneralDisorder,@Gloyale and possibly @idosubaru have done this before - if you have the time to share this information or the way you go about it, I and I'm sure other members, would really appreciate some guidance. Regards Bennie from Down Under Edited July 14, 2018 by el_freddo Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 14, 2018 Share Posted July 14, 2018 You buy standard rings, and install them. That's it. No measurement is generally required on standard bore sizes. You can check ring gap if you like. I've never had to gap standard sized rings. If you bore it oversized or are doing a special build with NOS or high boost, etc then you need to gap them for the application. I use NPR rings. GD 1 Link to comment Share on other sites More sharing options...
el_freddo Posted July 15, 2018 Author Share Posted July 15, 2018 Thanks GD! ill have to update how this went once I manage to get this engine together - it's a time issue more than anything. Cheers Bennie Link to comment Share on other sites More sharing options...
Crazyeights Posted July 15, 2018 Share Posted July 15, 2018 Link to comment Share on other sites More sharing options...
el_freddo Posted July 15, 2018 Author Share Posted July 15, 2018 You could be eating a lot of popcorn @Crazyeights! This build will be a slow burn so to speak! Cheers Bennie Link to comment Share on other sites More sharing options...
jono Posted July 15, 2018 Share Posted July 15, 2018 Try precision international for rings Bennie They supplied some Japanese made rings for my EA82T review last week. Actually before re-ring bores best be inspected for heat spots show up as round blemishes in my case Cast as opposed to chromoly for best bed in, though chromoly will last better if you can bed them in rev better too Every re-ring I have done I have used a flexible and splashed lots of Kero ( not ya wife!) about then handy Andy scrub clean before rebuild. Never a drama. Flexhone flexhone get it right !! Only once you have rings measure gaps in bore top middle and lowest point. Race engines use bigger gaps and is all worked out on per bore inch Link to comment Share on other sites More sharing options...
GeneralDisorder Posted July 15, 2018 Share Posted July 15, 2018 JFC - DO NOT HONE!!! Ya got that? People never listen. Honing is a disease. Flexhones are a gimmick. If your junk is that bad it needs to be bored. GD Link to comment Share on other sites More sharing options...
el_freddo Posted July 15, 2018 Author Share Posted July 15, 2018 @jono Have a read Previously mentioned article supplied by GD in another thread: http://www.snowvalley.20m.com/bikes/dnthone.htm This is the way I'm going Jono. Saves pulling conrods which saves big end bearing issues amongst other things Cheers Bennie Link to comment Share on other sites More sharing options...
kennycoulter Posted July 17, 2018 Share Posted July 17, 2018 cool link Link to comment Share on other sites More sharing options...
