I have an official reply from SofA about 2.5 HG problem!
My original Email:
"Hi!
I hope you can give me a definitive answer about
these Phase I engine head gasket problems? I'm looking into buying a
used Legacy Gt, they all have these Phase I engines. Just what IS the
problem? Is it simple the head gaskets themselves that blow? Are there
bad heads, that make the gaskets go? Are the blocks that these heads
and
gaskets are sitting on are bad? I hope you can give me an experienced
answer!"
Subaru of America reply:
Thank you for visiting the Subaru Web site and for your interest in
Subaru products! We appreciate you taking the time to contact us.
The WWP-99 Engine Cooling System Conditioner is a service program (not
a recall.) In short, Subaru has determined that over time, affected
vehicles may develop small external coolant leaks at engine cylinder head
gaskets. This is the result of normal expansion and contraction of
engine components caused by the heating and cooling of these parts. To
prevent cylinder head gasket leaks from developing or to correct existing
leaks, a special Subaru Cooling System Conditioner should be added to
affected vehicle cooling systems.
If you opt to purchase a vehicle affected by this program, you simply
need to contact your local Subaru dealership to schedule this service at
no cost to you.
I hope this information is helpful to you, but should you have further
questions, please let me know and I'll do my best to assist you
further.
Best Wishes,
John J. Mergen
Subaru of America, Inc.
the "service campaign" that he is refering to does not concern the phase I engines. the phase I engines have an internal leak, where cylinder pressure is blown into the cooling system. the phase II engines have an external leak, where pressurized coolant forces itself out of the block. a stop leak, which he was refering to, will correct the external leak, since it can plug the leak, but will do nothing for an internal leak, where it will be pushed out of the way.
my recommendation would be to stay away from all phase I engines. they have not proved to be a reliable engine. some will be fine, but it is a signifigant gamble that you should be well aware of from the get-go...
