SubeeTed Posted June 28, 2004 Share Posted June 28, 2004 My original Email: "Hi! I hope you can give me a definitive answer about these Phase I engine head gasket problems? I'm looking into buying a used Legacy Gt, they all have these Phase I engines. Just what IS the problem? Is it simple the head gaskets themselves that blow? Are there bad heads, that make the gaskets go? Are the blocks that these heads and gaskets are sitting on are bad? I hope you can give me an experienced answer!" Subaru of America reply: Thank you for visiting the Subaru Web site and for your interest in Subaru products! We appreciate you taking the time to contact us. The WWP-99 Engine Cooling System Conditioner is a service program (not a recall.) In short, Subaru has determined that over time, affected vehicles may develop small external coolant leaks at engine cylinder head gaskets. This is the result of normal expansion and contraction of engine components caused by the heating and cooling of these parts. To prevent cylinder head gasket leaks from developing or to correct existing leaks, a special Subaru Cooling System Conditioner should be added to affected vehicle cooling systems. If you opt to purchase a vehicle affected by this program, you simply need to contact your local Subaru dealership to schedule this service at no cost to you. I hope this information is helpful to you, but should you have further questions, please let me know and I'll do my best to assist you further. Best Wishes, John J. Mergen Subaru of America, Inc. Link to comment Share on other sites More sharing options...
LosDiosDeVerde86 Posted June 28, 2004 Share Posted June 28, 2004 SubeeTed said: My original Email: Best Wishes, John J. Mergen Subaru of America, Inc. I had a big e-mail argument with Mergen a while back about fuel economy. Link to comment Share on other sites More sharing options...
theotherskip Posted June 28, 2004 Share Posted June 28, 2004 the "service campaign" that he is refering to does not concern the phase I engines. the phase I engines have an internal leak, where cylinder pressure is blown into the cooling system. the phase II engines have an external leak, where pressurized coolant forces itself out of the block. a stop leak, which he was refering to, will correct the external leak, since it can plug the leak, but will do nothing for an internal leak, where it will be pushed out of the way. my recommendation would be to stay away from all phase I engines. they have not proved to be a reliable engine. some will be fine, but it is a signifigant gamble that you should be well aware of from the get-go... Link to comment Share on other sites More sharing options...
SevenSisters Posted June 29, 2004 Share Posted June 29, 2004 Like he said, "normal expansion and contraction of the engine". Just like the wheel bearings, sun visors, transmissions, fuel sending units, etc. I gotta keep mine running because I couldn't afford the repairs on a new one. Link to comment Share on other sites More sharing options...
Commuter Posted June 29, 2004 Share Posted June 29, 2004 Everyone can make a mistake, but that is a little sad that they guy didn't even clue in on the "Phase I" reference in your email. The answer isn't even pertinent! Commuter Link to comment Share on other sites More sharing options...
charlierh2 Posted June 30, 2004 Share Posted June 30, 2004 SOA rep train of thought: scan email, read "head gasket", copie and paste saved answer. Link to comment Share on other sites More sharing options...
