Jmpjose Posted July 25, 2018 Share Posted July 25, 2018 Hello. Having trouble with my electric choke. When the weather is hot i have no problem starting car and driving it around. Problem came when one morning it was a little cooler and engine would not stay on by itself only by playing with the gas pedal. I know this has to do with the choke. I currently have electrick choke conecyed to the back of alternator. Maby i need a different source of constant 12V from somewhere. I am using a weber carburetor any ideas were i can properly connect the electric choke too? I beleive power source should only be there when i turn the key. Thanks. Quote Link to comment Share on other sites More sharing options...
Knucklehead Saloon Posted July 25, 2018 Share Posted July 25, 2018 If you can't find an accessories on wire in the loom under the hood then run power from the red wire at the back of the radio. Cheers. Quote Link to comment Share on other sites More sharing options...
andrsn Posted July 27, 2018 Share Posted July 27, 2018 on my 83' brat there is a pink connector terminal near the right strut tower/ac stuff. it is a test terminal i believe and if I remember, one of them will supply 12v constant. you can use a multimeter to determine which one it is Quote Link to comment Share on other sites More sharing options...
