Hello.
Having trouble with my electric choke. When the weather is hot i have no problem starting car and driving it around. Problem came when one morning it was a little cooler and engine would not stay on by itself only by playing with the gas pedal. I know this has to do with the choke. I currently have electrick choke conecyed to the back of alternator. Maby i need a different source of constant 12V from somewhere. I am using a weber carburetor any ideas were i can properly  connect the electric choke too? I beleive power source should only be there when i turn the key.
Thanks.
on my 83' brat there is a pink connector terminal near the right strut tower/ac stuff. it is a test terminal i believe and if I remember, one of them will supply 12v constant. you can use a multimeter to determine which one it is
