JOEGIL Posted August 3, 2018 Share Posted August 3, 2018 What is the most straightforward tranny swap for a '92 SVX? Picked up a running, driving "92 SVX for $500, want to keep it on the cheap... Link to comment Share on other sites More sharing options...
Numbchux Posted August 3, 2018 Share Posted August 3, 2018 SVX, good luck getting a known-good one. EVERYTHING else requires at least swapping the rear diff as well. Link to comment Share on other sites More sharing options...
JOEGIL Posted August 3, 2018 Author Share Posted August 3, 2018 Thank you. As far as swaps, I've seen several combinations. I suppose i'm looking for the route that requires the least amount of fabrication/modification. Link to comment Share on other sites More sharing options...
wtdash Posted August 3, 2018 Share Posted August 3, 2018 (edited) Personally, I"d grab something from a '96-'99 OB/GT/Forester w/the EJ25D and 4EAT. The trans is likely plugnplay (get the TCU) + the rear diff swap is a 4.44 FD ratio which will increase your RPM's and make it quicker off the line. You'll lose the VLSD of the stock rear diff...but it's probably dead on the stock car anyway. Go checkout www.subaru-svx.net/ for specifics. If you want to tackle the 5-speed swap, that would elevate its performance even more. Edited August 3, 2018 by wtdash Link to comment Share on other sites More sharing options...
db***** Posted August 3, 2018 Share Posted August 3, 2018 I also bought my svx for $500. Same issue. Got 4eat tranny and diff from a Forester for under $600 I believe, off of car-part. Make sure you get it resealed at least, and make sure you get the matching differential from the same car. That is the most straight forward swap that I know of, considering the svx uses a 4eat. I have plans for a manual swap at some point. Link to comment Share on other sites More sharing options...
JOEGIL Posted August 3, 2018 Author Share Posted August 3, 2018 Thank you. A manual sounds great! Link to comment Share on other sites More sharing options...
