Personally, I"d grab something from a '96-'99 OB/GT/Forester w/the EJ25D and 4EAT. The trans is likely plugnplay (get the TCU) + the rear diff swap is a 4.44 FD ratio which will increase your RPM's and make it quicker off the line.
You'll lose the VLSD of the stock rear diff...but it's probably dead on the stock car anyway.
Go checkout www.subaru-svx.net/ for specifics.
If you want to tackle the 5-speed swap, that would elevate its performance even more.
Edited by wtdash
I also bought my svx for $500. Same issue. Got 4eat tranny and diff from a Forester for under $600 I believe, off of car-part. Make sure you get it resealed at least, and make sure you get the matching differential from the same car. That is the most straight forward swap that I know of, considering the svx uses a 4eat. I have plans for a manual swap at some point.
