Loyale Sedan, transmission selector lever, release relay?
Title says it all. The relay that is controlled off of the brake pedal, doesn't actuate anymore. Therefore I have to press the shift-lock button every time I need to go from Park to drive or reverse, etc etc.
Is there a switch that controls that relay that is tied to the brake pedal? Is this a common issue?
Thanks in advance for the advice.
On the last models of Loyale, they made a solenoid interlocked with the brake pedal that prevents the shift button from being pressed / lever from moving.  I'm more likely to disable the "feature"  since my 87 is identical, and does not have this interlock.
