ClassySoob Posted August 5, 2018 Share Posted August 5, 2018 Will dual headlights mount on my 85 GL? I really like the dual style headlights on the earlier 80s model subarus. I've seen a couple photos of them on the later models. Will the bolt up, or is there modification involved? Link to comment Share on other sites More sharing options...
el_freddo Posted August 5, 2018 Share Posted August 5, 2018 You need the units from the L series to make it work. Afaik it's a bolt in affair then mod wiring for dual headlights. The ea81 models need the radiator support panel swapped from the single to dual headlight unit from what I've been told. Cheers Bennie Link to comment Share on other sites More sharing options...
czny Posted August 5, 2018 Share Posted August 5, 2018 (edited) http://offroadingsubarus.com/headlight-relay-modification/ Daniel Stern Lighting.pdfUnavailable Binder1.pdf Edited August 5, 2018 by czny additional info Link to comment Share on other sites More sharing options...
alexbuoy Posted August 8, 2018 Share Posted August 8, 2018 it bolts right in. Link to comment Share on other sites More sharing options...
Subasaurus Posted August 9, 2018 Share Posted August 9, 2018 think he's talking about an EA82.. Make sure those corner lights are in good condition from your donor vehicle, they are ridiculously hard to find since they are skinnier and a different shape than regular EA82's. you need the buckets where the headlights sit, and i think you may also need the grille, it's been a few years since i've seen one so can't remember fully. Link to comment Share on other sites More sharing options...
czny Posted August 9, 2018 Share Posted August 9, 2018 (edited) Corner marker lights with pigtails, headlight buckets, headlight retainers & hardware, grill, lower headlight valance pieces & valance. Relays plus 4 headlight connectors. Some wire of course. Suppose you could get the complete front harness & do it that way. Wired mine so LED low beam is outers only, LED high beam is outers & halogen inners, fog lights are halogen inner low beam + fogs with separate switch. Was lucky enough to find an OEM fog light switch at a PNP yard. Headlight switch in turn signal assembly activates relays that are powered directly from fused battery source under hood. Edited August 9, 2018 by czny 1 Link to comment Share on other sites More sharing options...
Subasaurus Posted August 9, 2018 Share Posted August 9, 2018 On 8/9/2018 at 2:40 PM, czny said: Was lucky enough to find an OEM fog light switch at a PNP yard. Headlight switch in turn signal assembly activates relays that are powered directly from fused battery source under hood. Expand yeah that OEM foglight switch is alittle rare to find, i still have that switch in a box in the attic, was lucky too in 2013 to find a top of the line GL10 with one at the junkyard. Link to comment Share on other sites More sharing options...
