1991 Subaru Loyale fuel issues
Hey just bought a subaru loyale from a crack head and he said the issue with the car was head gaskets. Ofc those are probably bad too but a more interesting issue the car has is during start up. When turning the key on (not crank) i can hear the fuel pump turn on, then off. It will continue to do this for ever. Pump for about a second and a half then turn off. In about 5 second intervals.
When cranking the car it will start, rev up to 2k rpms then slowly fade out till it stops running. Is this car not getting enough fuel to sustain the engine? Is it the fuel pump relay?
I wasn't implying that the running behavior was the cause of the pulsating fuel pump. Quite the opposite, i believe the pulsating fuel pump was that cause of my running problems.
I disconnected the bright green connectors and there's no change in the fuel pump operation.
Pretty sure the problem is actually an air sensor being disconnected under the hood. PO has the thing half taken apart, i just want to get it in my garage.
yep, that's what I was thinking about.   There should be a green set and a white set of single pin connectors for diagnostics and reset.   they should be near each other.  Leave them disconnected for now.  Read the blinks on the LED under the steering column for codes.
If by air sensor you mean the MAF sensor attached to the air cleaner, then yes it could cause stalling, engine starts-revs-to-2000-then-dies, bucking while driving. My 87 is doing that right now.  Waiting on a reman MAF sensor as I've already done or checked everything else. MAF was original - 32 yrs.
