EdHsv Posted August 8, 2018 Share Posted August 8, 2018 I have a 2014 Subaru Outback. I would like to be able to sleep in the back in campgrounds with the hatch open, but when the hatch or any door is open, the LED lights along the exterior edges will stay on and never turn off. Is there any way to disable them, short of disconnecting the battery? Link to comment Share on other sites More sharing options...
golucky66 Posted August 9, 2018 Share Posted August 9, 2018 Manually close the latch on the hatch. Just push it in and it'll click. Car will think it's closed. Then when you want to close it. Hit the switch on the latch, it'll release it (just like opening the hatch in the first place) and you're done. 1 Link to comment Share on other sites More sharing options...
EdHsv Posted August 9, 2018 Author Share Posted August 9, 2018 Found the solution. Just use a screwdriver to move the latching mechanism on the hatch all the way to the "closed" position (two clicks). Lights will go off. To properly close the hatch, use the exterior rear hatch handle to pop the mechanism back into the opened position. If anybody knows any reason why this is not a good idea, please chime in. Link to comment Share on other sites More sharing options...
EdHsv Posted August 9, 2018 Author Share Posted August 9, 2018 On 8/9/2018 at 12:13 AM, golucky66 said: Manually close the latch on the hatch. Just push it in and it'll click. Car will think it's closed. Then when you want to close it. Hit the switch on the latch, it'll release it (just like opening the hatch in the first place) and you're done. Expand Thanks! I just now found this. Great minds and all that. 1 Link to comment Share on other sites More sharing options...
