Hello,
I have isolated a coolant leak to the small hose coming off the crossover pipe just to the side of the temp gauge, on the passenger side of the car, the hose seems to pass directly under the idle air control valve. I can not find a diagram or picture showing where this hose leads, so I am having a hard time determining what hose I need to purchase for a replacement.
I have a 2.2L EJ22 legacy.
Any help is greatly appreciated.
 The hose goes from the throttle body to the crossover pipe.
It acts as a return line that goes from the bypass pipe to the TB.
Its designed to keep the throttle body from icing up.
Some people in hot climates just bypass or plug them as icing is not a concern for them.
It will show up in service procedure for the TB.
Use an online dealer part cat. to look up the actual part no. if you  need it.
The dealer should be able to get it w/o a number.
Its on all the EJ22 and EJ25's at least up to 06.
O.
Edited by ocei77
add
  • Like 1
14 minutes ago, ocei77 said:
 not The hose goes from the throttle body to the crossover pipe.
O.
so that would mean the hose I need is the part 13 in the upper right corner of this diagram http://opposedforces.com/parts/legacy/us_b11/type_39/intake_and_supply_system_turbocharger/intake_manifold/illustration_4/ ?
Sorry to be so needy, I only know as much about cars as is required to fix things that have broken previously.
7 hours ago, Mike104 said:
I can't access opposed forces here.  But I think it is shown on this diagram
If so Part Number is 21144AA100
that's exactly the diagram I linked to and the part I was asking about! thanks so much for the help everyone!!!
