subpoop Posted August 20, 2018 Share Posted August 20, 2018 i installed the rubber brake hoses and got new pads. found out you can't tow the older subs on the ground without drive lines in. also found out the drive lines off a turbo didn't fit a regular transmission, to big on the tranny end in spite of what the parts boy at napa says. now i need to get a brake rotor, caliper and two drive lines. and find the loose ground wire under the dash. changed the ball joints, the old ones were rusted solid of course the boot tore installing it and the through bolt broke on one side. it was not a good day. but i can get parts at pull and save cheap enough as soon as the lady i bought the car from finds the title. then find some winter tires in 13 inch. good luck. 1 Link to comment Share on other sites More sharing options...
subpoop Posted December 24, 2018 Author Share Posted December 24, 2018 still waiting on the title and tires. Link to comment Share on other sites More sharing options...
Al Zhiemer Posted December 24, 2018 Share Posted December 24, 2018 Been looking around at tyres a lot lately, have stumbled across a lot of 13" and 14" winter tyres on the web... Doesn't mean they are still available in your area but there is at least hope. Cheers, Al Link to comment Share on other sites More sharing options...
FerGloyale Posted January 5, 2019 Share Posted January 5, 2019 to avoid confusion, please use the term "CV axle" or "half shaft" to describe what you are calling "drivelines" A "driveline" typically refers to the shaft between the trans and differentials. Since our cars trans have internal front diffs, we only have one " driveline" to the rear diff. Commonly called in the subaru world the "center driveline" or "rear driveline" or just driveline. Link to comment Share on other sites More sharing options...
el_freddo Posted January 6, 2019 Share Posted January 6, 2019 Or tail/prop shaft Cheers Bennie Link to comment Share on other sites More sharing options...
subpoop Posted January 13, 2019 Author Share Posted January 13, 2019 what brand of c/v tail/prop shaft should i get? all the old places go out of business or sell out to the chinese. my car is a 87 dl wagon. Link to comment Share on other sites More sharing options...
idosubaru Posted January 13, 2019 Share Posted January 13, 2019 hows the title? Propshaft and c/v are two different things but you’re saying both. For cv axles, reboot originals or get used ones. Aftermarket are trash. Link to comment Share on other sites More sharing options...
el_freddo Posted January 13, 2019 Share Posted January 13, 2019 On 1/6/2019 at 10:28 PM, el_freddo said: Or tail/prop shaft In reference to FerGloyale’s “driveline” term. Certainly not a driveshaft/halfshaft. Cheers Bennie Link to comment Share on other sites More sharing options...
DaveT Posted January 13, 2019 Share Posted January 13, 2019 If your original cv / front axels were damaged by the towing incident, look for used oem. Clean regrease and re boot. Lots of threads about this. For driveshafts - the one from the transmission to the rear differential, find a local driveshaft shop. A good one can get parts and rebuild them. Link to comment Share on other sites More sharing options...
sparkyboy Posted January 14, 2019 Share Posted January 14, 2019 Hankook makes a good snow tire for 13 Link to comment Share on other sites More sharing options...
