steve56 Posted September 4, 2018 Share Posted September 4, 2018 I want to read the srs fault codes for 07 Legacy. My Actron doesn't read srs or abs. Does Torque Pro have srs and abs? Link to comment Share on other sites More sharing options...
turboguzzi Posted September 4, 2018 Share Posted September 4, 2018 had good experience with PC based Scanmaster, upon connecting it lets you see a list of available ECU you can choose to connect to www.wgsoft.de Link to comment Share on other sites More sharing options...
montana tom Posted September 4, 2018 Share Posted September 4, 2018 I can tell you that a scanner that will read Subaru ABS starts at around $2500 !!!!! I'm sure that SRS is the same scanner. For some reason subi holds tight to that info. Only top of the line scanners can get access. I haven't heard of Scanmaster but its worth looking into. Link to comment Share on other sites More sharing options...
steve56 Posted September 4, 2018 Author Share Posted September 4, 2018 On 9/4/2018 at 9:03 PM, montana tom said: I can tell you that a scanner that will read Subaru ABS starts at around $2500 !!!!! I'm sure that SRS is the same scanner. For some reason subi holds tight to that info. Only top of the line scanners can get access. I haven't heard of Scanmaster but its worth looking into. Expand I can get to all the p and c codes without a scanner. I there a way to get to the srs codes without a scanner? Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 4, 2018 Share Posted September 4, 2018 I don't think the gauge cluster can access the SRS module like that. If it can I don't think it's documented anyway. As Tom mentions Subaru is pretty tough with scan tool support as they are not the first on the list for the aftermarket scan tool manufacturers. Snap-On may have one that can do it for less than $1k. Mine was $3k. GD Link to comment Share on other sites More sharing options...
steve56 Posted September 4, 2018 Author Share Posted September 4, 2018 On 9/4/2018 at 11:45 PM, GeneralDisorder said: I don't think the gauge cluster can access the SRS module like that. If it can I don't think it's documented anyway. As Tom mentions Subaru is pretty tough with scan tool support as they are not the first on the list for the aftermarket scan tool manufacturers. Snap-On may have one that can do it for less than $1k. Mine was $3k. GD Expand Thanks. I have a local shop that will read the srs codes. That will be my next step. Link to comment Share on other sites More sharing options...
idosubaru Posted September 5, 2018 Share Posted September 5, 2018 the overhead map lights are problematic with these sometimes - bad solder connection you can repair or get another map light. google it. the wiring harness under the drivers side seat. make sure nothing is pushing/pulling it improperly. can probably google that too. On older models you can ground a pin and get the SRS codes to flash - is that not possible with new models? Link to comment Share on other sites More sharing options...
steve56 Posted September 5, 2018 Author Share Posted September 5, 2018 On 9/5/2018 at 6:04 PM, idosubaru said: the overhead map lights are problematic with these sometimes - bad solder connection you can repair or get another map light. google it. the wiring harness under the drivers side seat. make sure nothing is pushing/pulling it improperly. can probably google that too. On older models you can ground a pin and get the SRS codes to flash - is that not possible with new models? Expand Yes I did the solder repair on map light assembly once with no luck. Will check the under drivers seat harness. There is supposed to be an eight pin connector under the dash by the steering wheel column that is an srs test connector Haven't found any info on line regarding how to jumper the pins to get srs codes. I know the error code for the map light assembly issue is 26. Would like to verify what code is actually turning on the srs light in my gauge cluster. Link to comment Share on other sites More sharing options...
idosubaru Posted September 6, 2018 Share Posted September 6, 2018 I think 2005+ you can't read the codes unless you have a $3,000+ scanner. older models you could ground a pin to flash the codes via the light on the dash using short and long blinks. the map lights fail frequently, maybe you can test it? Link to comment Share on other sites More sharing options...
steve56 Posted September 6, 2018 Author Share Posted September 6, 2018 I don't know how it could be accurately tested. I'm re soldering it tonight. I know they are $100 from the dealer and less than half that for a used one on Ebay. Both those options seem kind of a waste of money without knowing what is triggering the airbag light to come on. Link to comment Share on other sites More sharing options...
